I've been using my HP Pavilion dm1 notebook very successfully to drive a Samsung HDTV but we decided to move things around and I'm trying and failing to get it now to drive our Sony Bravia KDL 32-W5810 through the HDMI port. An image does appear on the TV screen but it's of the wallpaper only. Nothing active comes onto the TV screen although the laptop sreen is functioning perfectly. The wallpaper image aldo occupies only about half of the TV screen. Sound comes through the HDMI cable fine.
I'm not particularly technically minded but this makes no sense to me! Can anyone suggest what the problem might be please?
Thanks in advance
Try dragging a window off the edge of the laptop screen, so that only ~half the window is visible on the laptop screen. Try it at each edge of the laptop screen. Does the other half of the window ever appear on the TV screen?
If so, the second display has switched to extended desktop mode. Go to the graphics setup applet and change it to clone mode.
Weird Ripping Issue
By jackgardner73 in forum DVD RippingReplies: 4Last Post: 6th May 2013, 11:41 -
Weird no sound issue on tv.
By WinSpecToR in forum DVB / IPTVReplies: 3Last Post: 30th Oct 2012, 20:44 -
Weird DVD Burner issue
By Noahtuck in forum ComputerReplies: 1Last Post: 8th Nov 2011, 18:52 -
Vista/PD 150 communication issue
By kayaker in forum Capturing and VCRReplies: 10Last Post: 23rd Jul 2011, 21:32 -
Weird issue backing up DVDs
By downer in forum DVD RippingReplies: 6Last Post: 26th Aug 2008, 13:40
