My source is a DV PAL .avi file, with a resolution of 720x576 (at 25fps).
Would it make more sense to convert to a VCD with a resolution of 360x288 (half both ways) rather than the standard of 352x288, or won't it make any difference at all?
(P.S. I have tried with a sample, and couldn't REALLY notice anything, but I'm not expecting to see major differences, but every little bit helps.)
You should not use 360x288.
VCDs only support resolutions of 352x240 for NTSC and 352x288 for PAL.
The "pixel resolution" of VCD (or DVD for that matter) has absolutely nothing to do with the display aspect ratio of the video.
VCDs and SVCDs are always displayed on a TV with a display aspect ratio of 4:3 (i.e., it is expanded to fill the TV display).
DVDs are always displayed on a TV with a display aspect ratio of either 4:3 or 16:9.
Regards.Michael Tam
w: Morsels of Evidence -
oh... OK. It seems I don't fully understand that then...
It just seems weird that my .avi is captured at 720x576 (which IS 4:3, is it not?) whereas the VCD template/standard is 352x288.
(And like I said, 360x288 does burn (without compliance) and does play in my player). -
http://forum.vcdhelp.com/viewtopic.php?t=84647
360x288 may play on your player, but it isn't standard and your neighbors player may refuse to play it. There is no reason to encode to 360x288 instead of 352x288. As vitualis said, VCD and SVCD are always displayed with a Displayed Aspect Ratio of 4:3, no matter which resolution you chose, but the VCD PAL standard requires 352x288.
What's the best format and resolution for LCD TV or HDTV from DVD and VCD.
By newbievideohelp in forum Video ConversionReplies: 6Last Post: 6th Nov 2009, 13:23 -
High-Resolution VCD/SVCD Stills on the UNIX Command Line
By sterno in forum User guidesReplies: 7Last Post: 20th May 2009, 12:16 -
Need to convert VCD (352x288) into DVD and crop black bars off
By smashingly in forum MacReplies: 8Last Post: 10th Aug 2008, 05:12 -
512x288 or 352x288 and streched player to simulate 16:9
By Fking in forum Newbie / General discussionsReplies: 4Last Post: 7th Jun 2008, 08:30 -
I enter 352x288, but it always produces 320x240
By markwm in forum ffmpegX general discussionReplies: 2Last Post: 9th Jul 2007, 20:23
