  1. Hi there for some reason whenever I try to use MyMP4Box GUI it seems to crash on me... Any ideas on what could be causing this issue and how I can fix this?
    Nov 2002
    Make sure you have js32.dll in the tools folder with mp4box.exe. You can download it if not or you could uninstall and reinstall MyMP4Box GUI
  3. Yep js32.dll is in the tools folder of mp4box.exe... Any other reasons? OR is there other software that has ALL muxing demuxing splitting etc...?
  4. bump......
  5. Bump......
  6. bump......
    Nov 2002
    Did you uninstall and reinstall MyMP4Box? What operating system are you running? I'm running XP SP3 so I won't be much help if you're using a different OS.
    I usually just use Yamb unless I'm using Virtualdub with the external encoder. Then I use mp4box.exe but it either has to be in the MyMP4Box folder or the js32.dll has to be in the same folder with mp4box.exe. I don't really know what the problem could be except that I may have had to install a certain version of netframework. Without an uninstall and reinstall, I don't think you'll be able to find the problem.
  8. Okay I just tried YAMB and instead of joining the files I am trying to join it muxed them into one file when I used Join... So it had overlooping audio and picture (really weird)... I then retried MyMP4Box and it crashed at 98/100 again... So idk what the problem is...
