can anbody tell me that which is the best encoding software that can rip dvd in 700mb without lossing the video quality...
please help me guysss...![]()
Results 1 to 15 of 15
Encoding a 4 - 8GB DVD to a 700MB CD, you will lose quite a bit of quality. What final format do you want to convert to?
i will tell you only if you can tell me how many stars are there in the sky.
- not possible.software that can rip dvd in 700mb without lossing the video quality...
it sounds like converting Mercedes Benz into Mini Cooper without reduction in details and size.
surf the guide section here for ripping and converting DVD, you will come across many tools. -
If you want small size, then use H264; if you want play on old computers or players, then use XVid or Divx; file size and bitrate requirement big, but fastest than H264.
This depends your experience....without lossing the video quality... -
Here we are in 2013 and people are still trying to fit a DVD on a CD. Unbelievable.
guys plzzz suggest a software that could handle these encoding settings...
Encoding settings : cabac=1 / ref=10 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=1 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=29 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=745 / ratetol=1.0 / qcomp=0.70 / qpmin=3 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00 -
The Best is the one that gives you exactly what you want, In your case your desired encoding settings.which is the best encoding software
Have You tried any? if so, what you are not getting in which?
It always keeps changing. Yesterday's the best is today's the worst, and Yesterday's the worst is today's the best. Real World Scenario : Bad News is there is so such things as "The Best". -
If you COULD get 5-8GB of data down to 700MB without loss of quality, don't you think Hollywood or DVD player manufacturers would have been doing it for years?
The best MPEG 2 encoding software?
By whatever911 in forum Video ConversionReplies: 20Last Post: 8th Oct 2012, 08:54 -
On the fly software AC3 encoding
By djdynamite123 in forum AudioReplies: 12Last Post: 24th Jul 2011, 16:35 -
Encoding Software
By Laserbelly in forum ComputerReplies: 4Last Post: 11th Oct 2010, 18:20 -
Hardware vs Software Encoding
By gabs247 in forum Capturing and VCRReplies: 49Last Post: 28th Mar 2010, 19:31 -
Software or hardware encoding for project?
By stantheman1976 in forum Video ConversionReplies: 2Last Post: 11th Jun 2008, 15:53
