Hello!
Having moved from kmplayer to potplayer i'm still missing some of it's old options.
I've seen bookmarks being advertised and mentioned for potplayer but i can't find or add them anywhere in the menus. How does it work?
Also i have some skins with detachable playlist. Is there a hotkey to do this for other skins or is it skin based?
Currently it only works during playback and the playlist seems to be a skin based feature.
ps. There should be one bookmark at least to enable bookmark menu. It is in playback menu. Once you created a bookmark, the menu will be activated.Last edited by sheppaul; 31st May 2013 at 05:24.
Haven't used potplayer lately ... I don't use windows much anymore and it was a distant 3rd for me behind smplayer and vlc ... but you don't need any added skins for bookmarks. Though they're not exactly detachable, if you enable the playlist display you can bring them up by moving the pointer to the right.
Bookmark is under right-click -> playback as I remember.
Actually, except for the fact that potplayer doesn't install or need extra codecs, the bookmark feature is the only reason I'd recommend it. I've never seen another player that makes them easier.
Though with smplayer you can set it to automatically remember the playback time position when you stop or shut it down, which means I don't need bookmarks all that much. And it's way better in general. -
Aa thank you.
You have to be playing the file for the bookmark menu to open. P to add bookmark, h to open the menu. Strangely it doesn't show up in the hotkeys unless you are playing the file already.
Reading AVCHD Playlist files BDMV\Playlist\*.mpl
By StrangeSolutions in forum Newbie / General discussionsReplies: 11Last Post: 10th Jun 2014, 23:23 -
Potplayer: adding files to desired position in playlist.
By qwecxz in forum Software PlayingReplies: 5Last Post: 3rd Feb 2014, 22:02 -
PotPlayer BD Seamless Playlist (bug report)
By katipo in forum Software PlayingReplies: 3Last Post: 17th Feb 2013, 06:21 -
Potplayer playlist question
By rennes in forum Software PlayingReplies: 4Last Post: 1st Dec 2012, 01:03 -
How to get bookmarks from Firefox?
By newworldman in forum ComputerReplies: 10Last Post: 26th Feb 2010, 19:33
