Which when resized for playback will look something like this:
Results 31 to 43 of 43
The OP wants to convert from PAL DVD to NTSC DVD. So he's interested in the retaining the correct DAR. He's not interested in square pixel encoding. Since your PAL DVD source is 16:9 DAR, and he presumably would want to make a 16:9 DAR NTSC DVD, all he has to do is resize the 720x576 frame to 720x480. There's no need to crop, resize, then add borders.
Of course, if the source video is interlaced everything changes.Last edited by jagabo; 3rd Jun 2013 at 07:34.
Figured I'd rather bump this than create another 'PAL to NTSC' thread...
What is the best de-interlace method (w/ decent quality and without jitter) for a PAL to NTSC conversion? The PAL dvd's field-order is Top Field and it was captured from a VHS tape.
I also plan on uploading the final output to Youtube. Thanks.Last edited by chef2; 8th Aug 2013 at 17:58.
In the future we'd actually prefer that you just make a new thread. We don't want to turn into another AVS Forum where all the threads run 1000+ posts and it becomes just about impossible to find any useful information any more. One guy started this about a specific problem he faced. It was never intended to become a "from now until the end of time all PAL to NTSC questions must go here" kind of thing.
And make sure you're video is really interlaced. PAL is often recorded out of phase -- the two fields of each frame come from different film frames rather than from the same film frame. These are easily restored to progressive film frames with TFM(). Or SeparateFields().Trim(1,0).Weave().
Thank you for the suggestions.
@manono - I'm looking to edit/encode the DVD to an h264 file that is ready and playable for Youtube. I normally work with NTSC SD footage (captured from VHS) and render out to 640x480 @ 29.97fps. With this PAL DVD, though, playback and motion is pretty awful.. err, jittery.
@jman98 - will do, thanks
@jagabo - here's a sample of what I'm working with (it's bad, I know):
http://www.sendspace.com/file/ez89pe -
It's field-blended from an NTSC video source and in a way I don't know how to unblend (or can't be unblended back to NTSC video). I think I'd just deinterlace it. Maybe jagabo or someone else has a better idea.
I don't see any way to deblend that video either. For interlaced NTSC DVD I'd try something like this:
Code:function SmoothFPS2(clip source, int num, int den) { super = MSuper(source, pel=2, hpad=0, vpad=0, rfilter=4) backward_1 = MAnalyse(super, chroma=false, isb=true, blksize=16, searchparam=3, plevel=0, search=3, badrange=(-24)) forward_1 = MAnalyse(super, chroma=false, isb=false, blksize=16, searchparam=3, plevel=0, search=3, badrange=(-24)) backward_2 = MRecalculate(super, chroma=false, backward_1, blksize=8, searchparam=1, search=3) forward_2 = MRecalculate(super, chroma=false, forward_1, blksize=8, searchparam=1, search=3) backward_3 = MRecalculate(super, chroma=false, backward_2, blksize=4, searchparam=0, search=3) forward_3 = MRecalculate(super, chroma=false, forward_2, blksize=4, searchparam=0, search=3) MBlockFps(source, super, backward_3, forward_3, num, den, mode=0) } Mpeg2Source("sample.d2v", CPU=6, Info=3) AssumeTFF() QTGMC(preset="fast") SmoothFPS2(60000,1001) BicubicResize(720,480) SeparateFields() SelectEvery(4,0,3) Weave()
colorspace conversation elaboration
By mammo1789 in forum RestorationReplies: 13Last Post: 18th Nov 2011, 14:36 -
need a quick refresher course/ conversation
By jameskiehl in forum Newbie / General discussionsReplies: 11Last Post: 18th Mar 2011, 16:20 -
Problems with VOB Conversation
By Sundayarak in forum Video ConversionReplies: 7Last Post: 7th Jun 2010, 08:37 -
help, Flv to Hd conversation with XviD4PSP
By betalb2008 in forum Video ConversionReplies: 1Last Post: 15th Nov 2008, 14:10 -
an anoying problem with subtitles and conversation.
By d2idan in forum Video ConversionReplies: 10Last Post: 13th Jun 2008, 17:54
