hi. just wanted to say I came here to learn from the OP's question and your valuable answers related to the topic. However, I think the sidetracked discussion is hijacking the thread. I wish I could say I still learned much from them too, but I just skipped over them
Yet, at least I can see that Stears555 is continuing the discussion despite requests for ending it. Well, please consider my message as an outsider's request too, to come back to the original topic.
Results 31 to 37 of 37
Are you a multiplicated name of Cornucopia? They simply lost the debate, and they can't sustain the situation as gentleman.I always warn the purchasers that DSLR-s cameras produce weaker videos than top consumer camcorders. What's wrong with it?
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
A couple years ago, I bought a Canon T3i from reading all the reviews on how great it shoots video, and that turned out to be hype. In reality, the recorded video is blocky, probably the codec is no good. It's not visible until you start doing color work.
And something else you mentioned is true, that camcorder makers mix optical with digital when referring to the sensor as well as the lens. But in the case of the T3i, although it has a bigger sensor than any camcorder, the codec used was crippled. That's why independent filmmakers use the HDMI-out port to a recorder to capture 4:2:2 straight from the lens.
But the average "joe" doesn't "get" this part until it's too late, and you can't undo the purchase. So I ended up buying a dedicated camcorder, and use my T3i for stills. It's an awesome still camera.
Another comment you made it true that the 1/3CMOS sensors DO have low native pixel count, like 700-ish, and they interpolate it to 1080. This softens the image, and is the main reason they're prosumer, not pro.
As far as camera operators not knowing the technicals, that's probably true too, because they're experienced as "capturers", not "editors".
And P.S. cornucopia(Scott) is a pro, and knows his stuff. He's a stickler, and that's a good thing for us. He cuts through the bullarky. "Bullarky" is regular melarky with variable amounts of BS rolled into it. Bullarky has elements of truth mixed in, so it sometimes passes muster. We depend on users like Scott, and others to step in and clarify.Last edited by budwzr; 14th Jun 2013 at 11:01.
Video from Camera displays incorrectly on comptuer, but fine on camera & TV
By g6qwerty in forum Video ConversionReplies: 2Last Post: 31st Jan 2013, 23:02 -
Mini DV tape recorded with Cannon camera plays no audio on Sony camera
By dalitso in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 21st May 2012, 18:05 -
Best camera to pick if you have a HDV camera already
By Cazz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 29th May 2011, 15:58 -
DV camera maintenance? (also evaluate my camera)
By CursedLemon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 12th Jul 2010, 09:28 -
SD Video Camera Vs. HD Movie Mode on Digital Still Camera.
By CP/M User in forum Newbie / General discussionsReplies: 20Last Post: 20th Nov 2009, 15:57
