  1. Hi
    I have been capturing videos with no problems but when I am going to capture with a Cassette adapter like this:
    It is capturing in black and white, I dont know why, in my tv when I see this videos with that adapter and that VCR I see them in colour. I have used almost all the capturing software and none of them is working. I set the options in composite video + NTSC, when I set in composite video + PAL the image goes in colour but it freezes
    What could be the problem? Thanks and sorry for my english.
    Aug 2006
    You are trying to capture an NTSC tape played back with a PAL VCR.The VCR outputs a PAL 60 signal, which has NTSC resolution and frame rate, but uses the PAL color system. Does your capture software allow you to use a PAL 60 setting for the capture device?
