I have had good results using Streamclip until now. When I try to load this one particular MPEG 2 file, Streamclip immediately freezes up. The file opens fine in Mpg2Cut2 and plays fine in VLC and WMP 11. I searched for info using 'Streamclip freezes' but found nothing that addresses freezing when opening a file. Any clues?
Here is the MediaInfo for this file:
General
Complete name : D:\TV\New Folder (2)\60.1 KCSM(29-05-13 03-00-03).MPG
Format : MPEG-PS
File size : 5.03 GiB
Duration : 57mn 19s
Overall bit rate : 12.6 Mbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=30
Duration : 57mn 16s
Bit rate mode : Variable
Bit rate : 12.1 Mbps
Maximum bit rate : 90.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Active Format Description : Letterbox 16:9 image
Frame rate : 29.970 fps
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.195
Time code of first frame : 19:22:28;08
Time code source : Group of pictures header
Stream size : 4.85 GiB (96%)
Audio
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Muxing mode : DVD-Video
Duration : 57mn 19s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Delay relative to video : -783ms
Stream size : 78.7 MiB (2%)
Text
ID : 224 (0xE0)-CC1
Format : EIA-608
Muxing mode : A/53 / DTVCC Transport
Muxing mode, more info : Muxed in Video #1
Stream size : 0.00 Byte (0%)
Thanks,
Jack
As I recall from my efforts to use it for editing my recorded TV shows, the Windows version of MPEG Streamclip has difficulty opening HD MPEG-2 TS files, and your file is 1080i.
Thanks, uq
This is the only video I have at 1080i, so what you posted tends to make sense.
MPEG Streamclip MPEG-TS to MPEG4/H264 (file size & aspect ratio query)
By Heathy65 in forum Video ConversionReplies: 5Last Post: 4th Apr 2012, 11:31 -
Why Can't I convert the whole file in mpeg streamclip?
By alphonsecpone in forum Video ConversionReplies: 0Last Post: 5th Mar 2011, 09:24 -
Help !!Convert a trp file with Mpeg streamclip
By caliman in forum Video ConversionReplies: 0Last Post: 21st Oct 2010, 11:55 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30
