Results 31 to 38 of 38
Hmm..I wasn't aware that there is 16:9 SD. Everything that I've shot and edited for DVD in the past has been 720x480
Yes, it's been around for at least 20 years.
Here's an explanation:
http://www.dvdbeaver.com/film/misc/anamorphic_dvd.htm -
you cannot see the difference between 4:3 and 16:9 DVD, just looking at resolution, both have the same resolution, 720x480, the difference is aspect ratio,
it is an efficient solution to be able encode 16:9 into full available resolution 720x480 for SD, and then just give it a flag 16:9 while authoring so any player will grant this and renders 16:9 ratio on screen -
If you bring a 1920x1080 source into Encore and create a timeline it will automatically assume it is 16:9. If you see something else, such as a 4:3 picture with bars on the top and bottom, right click on your source, choose interpret footage, and change the "conform to" options until you have a proper 16:9 filled frame.
If you see thin black bars on the edges, that's fine. -
I will have to do some experimentation. I may not use Encore as Adobe has some weird new monthly pricing creative cloud thing. What ever happened to just being able to buy a piece of software? Hopefully my older version of Encore will run on Windows 7...
Authoring oversized DVD, then shrink to fit on a disc?
By adamberkey in forum Authoring (DVD)Replies: 1Last Post: 28th Apr 2012, 00:39 -
MultiAVChd authoring problem (HD + SD on 1 disc)
By digitalfreaknyc in forum Authoring (Blu-ray)Replies: 3Last Post: 22nd Jul 2010, 17:36 -
file types when authoring a blue ray disc
By michcio in forum Authoring (Blu-ray)Replies: 2Last Post: 18th Jan 2010, 13:47 -
Disc writing tool not working in TMPGEnc dvd authoring 4
By egor909 in forum Authoring (DVD)Replies: 3Last Post: 22nd Nov 2009, 06:14 -
Tools for authoring several divx files in a disc
By Paco M. in forum Newbie / General discussionsReplies: 10Last Post: 13th Jun 2008, 17:33
