    Aug 2002
    Canada
    trying to convert this mp4 file and the output ends up being all discoloured and distorted somehow.. never seen this happen. here is the directshow filter graph, will this help someone sort out my issue?
  2. There is a redundancy in the audio decoding chain: uninstall AC3Filter and have ffdshow only to handle audio.
    About the video issue, I would suggest to try with FFMpegSource instead of A2DSource ('Preferences'/'AviSynth'/'AVS Video Source Filter').
    Before starting to encode, use the 'Preview Clip' option to simulate the output.
    Bye
    MrC
    AVStoDVD Homepage
    Aug 2002
    Canada
    where is AC3filter, checked add/remove its not listed.. or search pc and cannot find it, program files etc..
    i changed the preferences to FFMpegSource and preview output and video and sound looks great. WIll this work now?
    Aug 2002
    Canada
    update, it now converted great, no issues on video.. so just by changing the preference to FFMegSource it worked.. no need to unsinatll AC3filter, audio is fine too in sync. thanks!!
