So i googled far and wide for a solution to this problem, however I could not find one. Forgive me if this is the wrong section to post this in, but here is my problem.
Whenever I try to just play my games using my Blackmagic Intensity Pro capture card on virtual dub in preview mode I only get 10 FPS. When I re size the window it goes back to 60 FPS as seen in the second picture. I'm thinking that it couldn't be my computer being too slow because it worked before just fine then I formatted, and it hasn't worked since. Here are my computer specs if you need them. Thanks for any and all help!
AMD Athlon 64 x2 dual Core Processor 6000+ 3.00 GHZ
4.00 GB RAM
HD 3870
Windows 7 64-bit
Explain how you did the os reinstall ?
Check your using current drivers for the motherboard and video chipset.
Virtual Dub setting help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 10Last Post: 27th Oct 2011, 17:55 -
preview mode in the timeline Using Sony Vegas Studio Platinum 10
By JackDalton in forum EditingReplies: 5Last Post: 26th Oct 2010, 03:16 -
Virtual Windows XP mode with W7 Home Premium?
By neworldman in forum ComputerReplies: 3Last Post: 4th Oct 2010, 12:45 -
Need help with Virtual Dub setting
By lost123 in forum Capturing and VCRReplies: 12Last Post: 8th Jul 2010, 21:31 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48
