I have a video with 2 audio streams; the first is english, the second is spanish. I want to convert the file using only the second stream (spanish)... I select the option, i uncheck the first stream in the options, so i just want to use the second audio... The preview plays the video with the second audio, ok, everything is fine...
Once the convertion is done i play the final video and what i hear? It was converted with the first audio only (english). Regardless how and what configuration i use to explain the software i just want the second audio only it keeps converting using only the first audio...
Tried with several other videos with same characteristics with the same results.
It doesn't matter if is an mp4, mkv, avi or mov, is always the same...
Any leads? Suggestions? Another decent video converter? anyone? help?
You could remove one audio track with mkvtoolnix or mymp4boxgui and make new mkv or mp4 that should work better to reconvert.
Or try other converters like tencoder, video to video converter, handbrake and stay away from xilisoft crap.
Xilisoft Video Converter Bitrate output problem
By mehcha in forum Newbie / General discussionsReplies: 1Last Post: 3rd Aug 2012, 06:58 -
Xilisoft video converter help
By paul278 in forum Video ConversionReplies: 3Last Post: 18th Sep 2011, 06:12 -
By Vman94 in forum Video ConversionReplies: 0Last Post: 12th Jul 2011, 12:35 -
Xilisoft Video converter from mvk to dvd - audio problem
By sychern in forum AudioReplies: 4Last Post: 10th Oct 2008, 03:57 -
WMV to AVI using Xilisoft Mac Video Converter
By BassJunkie in forum MacReplies: 11Last Post: 30th Jul 2008, 03:31
