Unfortunately the video has to be encoded using the same method and encoder settings etc or it can't be joined together. The same applies to audio. I don't mess around with TS files much but if MKVMergeGUI can't join them I'd suspect nothing will.
Video To Video Converter has a "join files" function you could try (under the tools menu). If that doesn't work you might have to re-encode the ts files you're wanting to join as one single encoding job. I'm pretty sure Video To Video Converter will let you join multiple input files together and output a single encoding job. If not, I'm fairly sure AnyVideoConverter can do it. I've no idea if AVIdemux can as I don't use it.
Results 31 to 34 of 34
Capturing a video with ffmpeg does not output audio when played
By oban in forum Capturing and VCRReplies: 0Last Post: 3rd Jun 2011, 11:11 -
Avidemux (Ubuntu 10.10) movie is played in slow motion
By Toonyto in forum EditingReplies: 0Last Post: 21st Jan 2011, 07:51 -
MPEG clips play from cache but truncated when first played from online
By njaounteisc in forum Newbie / General discussionsReplies: 2Last Post: 19th Mar 2010, 13:01 -
Please help! Corrupted x264 video preview/output in AviDemux
By bigshotceo in forum EditingReplies: 1Last Post: 31st Dec 2008, 09:48 -
AviDemux - Uncompressed AVI Output
By hech54 in forum Video ConversionReplies: 12Last Post: 29th Sep 2008, 12:00
