Hello,
could someone please suggest to me a simple program that will allow me to mux an h.264 mkv file into an mp4 container? I've tried mkvtomp4 but that didn't work for some reason, just stayed at 99% the whole time, and I tried meGUI but have no idea how to use it.
Any help would be much appreciated, thanks.
Results 1 to 11 of 11
Not all mkvs can be remuxed to a mp4 container.
But you can always try avidemux, open mkv, under video and audio choose copy, under container mp4, save. It will probably crash though...
Or from a command line, ffmpeg -i video.mkv -vcodec copy -acodec copy video.mp4
If everything fails you might have to reconvert the audio or video. Post the details from the mkv then. -
Download ffmpeg(get the latest static 32bit build), extract ffmpeg.exe, put it in for example c:\temp together with your mkv file.
Start a command prompt from the windows start menu and under accessories.
Type
cd c:\temp
ffmpeg -i "video.mkv" -vcodec copy -acodec copy video.mp4 -
Okay, i will give it a try, but I should have asked you this before... Can i still do this without any audio?
I just need the video stream, no audio. In fact it's crucial that I don't have any audio in the file (don't ask, long story). -
Okay,
It kind of worked, but the mp4 file is horribly choppy. I don't know what i've done wrong.. -
You can also try Video To Video Converter. When you open an MKV for conversion, select Direct Stream Copy from the conversion presets.
Cannot seem to convert MKV to MP4 or AVI to MP4 without audio sync issues
By Matth3w in forum Video ConversionReplies: 0Last Post: 16th Sep 2012, 13:36 -
Simple MKV to MP4 Conversion Guide (Xbox360)
By Cloud101 in forum User guidesReplies: 35Last Post: 8th Nov 2011, 16:41 -
Simple Guide : How to rip BD to mkv or mp4
By Bonie81 in forum Blu-ray RippingReplies: 8Last Post: 21st Jun 2011, 13:00 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 05:44 -
Simple MP4 Video Editing Program
By BTJustice in forum EditingReplies: 6Last Post: 24th Feb 2010, 09:36
