  1. Is it possible to burn (S)VCD's on CD Re-Writables, and then wipe them? Something I'd like to do is download movie trailers and show them for my local club. Of course trailers aren't very long, and the most I'd ever show is not longer than half an hour. It seems to me a waste to burn only a small amount onto a CD which is only going to be used once. If I can use a CD R/W I can burn it, show the trailers, and then wipe it, ready for the next month's meeting.
    Thanks for your help,
    Widya Santoso
  2. Banned
    Apr 2001
    Calgary, Canada
    Of course you can burn them on CD-RW's -- You can put anything on a RW that you can a normal CD. Question is, assuming you want to play them in a DVD player, will your player READ the RW disc? Thats the thing you want to test.
