Hi,
How can i do editing the track id in a mov file.
Which command line option help me to achieve the same?
I am aiming to pack a video & audio (in separate files,formats MPEG-2 & RIFF wav respectively) in to a .mov file.
I am able to produce the .mov file but the track id (In media info number with heading IDis default(when it created) and it is 1 for video, 2 for audio. But i need to change this by 3 and 4 at the time of creation it self. How can i achieve the same?Which command line option help us? Any other solution for the same ?
Few more explanation about my problem
I read from internet, i can edit the stream ID which display as ID:# in media info.
The text written as follows
Based on this i gave the command line as follows
-streamid output-stream-index:new-value
Assign a new stream-id value to an output stream. This option
should be specified prior to the output filename to which it
applies. For the situation where multiple output files exist, a
streamid may be reassigned to a different value.
ffmpeg.exe -i F:\ExpMov\ExpQT\ProRes.mov -i F:\ExpMov\ExpQT\audi1.wav -i F:\ExpMov\ExpQT\audi2.wav -i F:\ExpMov\ExpQT\audi3.wav -map 0:0 -map 1:0 -map 2:0 -map 3:0 -streamid 1:12 -streamid 2:13 -streamid 3:14 -acodec copy -vcodec copy -timecode 09:59:40:00 F:\ExpMov\ExpQT\Mov_Created.mov
But still i get the same sequence like video ID 1 Audio ID 2.....
ffprobe.exe -show_stream option does not show this value, it shows index.
But some other tools while playing the file took the ID value.
Friends could any body review my command and let me know any mistake is imposed.
OS :- Windows 7 64 bit
ffmpeg version info
Thanksffmpeg version N-53380-g0fb7fef Copyright (c) 2000-2013 the FFmpeg developers
built on May 23 2013 14:19:35 with gcc 4.7.3 (GCC)
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av
isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab
le-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetyp
e --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --ena
ble-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-l
ibopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libsp
eex --enable-libtheora --enable-libtwolame --enable-libvo-aacenc --enable-libvo-
amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --
enable-libxvid --enable-zlib
libavutil 52. 33.100 / 52. 33.100
libavcodec 55. 11.100 / 55. 11.100
libavformat 55. 7.100 / 55. 7.100
libavdevice 55. 1.101 / 55. 1.101
libavfilter 3. 69.101 / 3. 69.101
libswscale 2. 3.100 / 2. 3.100
libswresample 0. 17.102 / 0. 17.102
libpostproc 52. 3.100 / 52. 3.100
Dave
Results 1 to 9 of 9
Hopefully this answer is of some help.
In addition, the command line above starts reassigning stream IDs from 1, i.e. stream ID 0 will remain unchanged.
If ProRes.mov contains any additional tracks other than the video you want, you may need negative mapping to exclude those from the output. An example from http://www.ffmpeg.org/ffmpeg-all.html#Advanced-options:
Cheers,Code:To map all the streams except the second audio, use negative mappings ffmpeg -i INPUT -map 0 -map -0:a:1 OUTPUT Note that using this option disables the default mappings for this output file
FrancoisLast edited by fvisagie; 28th May 2013 at 04:30.
Hi Francoi,
I agree with your suggestion but my requirement is different.
The audio and video are in individual files with stream index 0 and stream id/track id 1.
I am trying to map this separate content to single mov file and the desired orientation as follows
index 0
track id 1
video [input file 1]
index 1
track id 3
audio[input file 2]
index 2
track id 4
audio[input file 3]
index 3
track id 12
audio[input file 4]
More precisely the track id which is part of 'tkhd' atom. I am looking for how to edit the same..
Welcome to your thoughts.
Dave -
You could easily get the tracks in using QTPro, but first: WHY do you need specific track IDs? Most, if not ALL, apps will create consecutive stream #s (per type) when muxing. And most playing/editing apps use the stream#s for handling ident purposes only anyway - they would rarely require a particular stream to exist in a particular extended stream# (not counting first video & first audio, which many apps take for granted and assume exist).
ScottLast edited by Cornucopia; 28th May 2013 at 18:46.
Hi Scott,
I need to add tone at start of audio track.So extract the original audio.Add tone at start + data from original and put back to mov file. I don't want any change in the mov anatomy or meta data.
Dave -
When you talk about adding tone, is that appending (increasing the duration of the clip) or inserting (maintaining the duration)?
Have you tried just demuxing, editing the audio and re-muxing, to see how well that worked?
Which metadata are you needing to be intact that you think will be destroyed/altered?
Scott -
Hi Scott,
Thanks to your question.
The tone is inserting at start of the audio.
Demux the video(in native format) and audio(in pcm format) kept it in separate files. Also hold the timecode information from the tmcd track.After audio editing i intent to remux.In my case no change in video/tmcd track. Modification only comes in to audio.
Issues
1) Preserving track id.
My original file had track id 1 for video, 12 for first audio track, 13 for second audio track.
But after remuxing i lost this and got track id 1 for video,2 for audio first track,3 for audio second track.
Due to this my automation scripts failed.What is the solution for the same ?
could you know.
ffmpeg gave any api support to preserve track id.?
Is it possible to replace the audio content only in the original file without alter any metadata?
Dave -
What automation scripts? Maybe they can be modified to more versatilely adapt to stream changes...
<edit>maybe you could inert/replace the silent bytes with the tone bytes using a hex editor - that will certainly not mess with all the other data/info (as long as you correctly swap according to packet/chunk/sector boundaries).
ffmpeg to replace audio track?
By yetanotherlogin in forum EditingReplies: 2Last Post: 30th Apr 2013, 19:32 -
Mov TimeCode Track Info
By Dave1024 in forum Video ConversionReplies: 4Last Post: 17th Oct 2012, 01:19 -
How do I write an ffmpeg script that will simply strip the audio track?
By Iced Coffee in forum Newbie / General discussionsReplies: 1Last Post: 18th Jan 2012, 09:55 -
FFmpeg / FFmbc ---> 8 Mono track to 1 Stereo
By elmuz in forum Video ConversionReplies: 2Last Post: 13th Jun 2011, 07:06 -
[FFmpeg] Problems encoding a MOV
By Klagar in forum Video ConversionReplies: 0Last Post: 29th Apr 2011, 12:18
