Hey, computer programmer based in Asia here.
My goal is an interactive LCD wall like this one http://www.youtube.com/watch?v=zyV44YoBwqg&feature=player_detailpage#t=25s
The broad size range for the screens is explained by the fact that I can adapt depending on the size of the screens (4x4 for smaller ones and 3x3 or even 2x2 for larger ones... you get the idea), depending on how it will look and what I need at that particular time in the end.
I do not want touchscreen capability, this will be handled separately.
The key word being low cost, image quality is less important as long as it is LCD (LED screens would be too low res).
Question is, does anyone have experience/know of good source of low cost LCD screens between 15"-40" ?
Thanks in advance.
	If image quality is not important than what difference does it matter if it is LED ?image quality is less important as long as it is LCD (LED screens would be too low res).
 And LED is how it is "LIT UP" and has nothing to do with resolution.
 And that looks like something either custom or very very expensive as it obviously has no frame/borders between them in the middle but you can see the lines where they are separate screens.
 It also is not a standard AR for a screen.
 I don't think "low cost" fits anywhere when it comes to something like that, but then again, I guess it depends on your definition of "low cost"
	Maybe the OP is thinking of the digital signage one sometime sees, such as current "JumboTron" displays, where the "pixels" are actual LED lights, and not LCD displays with LED backlighting.
 I agree that custom-building a display using several re-purposed LCD panels would not be an inexpensive project.
  Looking for Low Cost (Cheap) Stock Footage for Editing ProductionBy HoosierGuy in forum EditingReplies: 3Last Post: 13th Feb 2012, 06:07
  Headsup on Samsung LCD TV screensBy ranchhand in forum Newbie / General discussionsReplies: 15Last Post: 28th Dec 2010, 09:10
  Do I need a NLE & Is there a free/low cost one available?By TBoneit in forum EditingReplies: 2Last Post: 17th Sep 2010, 12:08
  Is nvidia 3d a low cost way to 3dtv?By yoda313 in forum ComputerReplies: 6Last Post: 3rd Jul 2010, 01:35
  Why can I get a low cost learning remote ?By SingSing in forum Newbie / General discussionsReplies: 7Last Post: 27th Mar 2010, 20:35
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
