Hello , i load the video file WMV , i add .ASS subbtitles and i don't know how to save the video with the subs , where i need to click?
Results 1 to 16 of 16
Once your file is ready to convert, click 'Enqueue' and then the 'Encode' tabs.
On the left of screen, click just beneath 'Format' select AVI or MP4 preset of your choice.
Do the same with the other settings: 'Filtering', 'Color correction' etc..
The small cog-shaped icons provide further tweaks if you want to fine adjust anything.
Then click 'Enqueue' and the 'Encode' tabs. -
Why are you using xvid in an mp4 container? in Video encoding settings use x264.
http://www.longtailvideo.com/support/jw-player/28838/mp4-video-encoding/
Use AAC audio not AC3 (it will work but may not be compatible with certain players, or even Sony Vegas). -
Jeez, why not cut a section and test it first! lol
xvid4psp has a trim funtion... -
You just started with video editing, right?
Or not?
For "Cut" use the preview and choose the start; when you want click on Set Start button. For the end the same and click on Set End button. At last click on Apply Trim and Encode... -
I am glad that I searched and noticed the reply by 'transporterfan' to the OP. I had just installed XviD4PSP (v5.10.330.0 - 19.03.2013) and was getting used to the trim controls but I could not get the encoded video to play. The Winnydows home page had some comments but nothing like VideoHelp. I now know to Enqueue my project before Encoding it. It would be helpful if there was a PDF or Manual for v5. I am a fairly light user and can't justify being pressured to "donate" €14 for the latest version 8.
Xvid4psp help
By skorpinok in forum EditingReplies: 2Last Post: 26th Jun 2011, 21:28 -
Help with Xvid4Psp
By xNesX in forum Video ConversionReplies: 3Last Post: 19th May 2011, 08:22 -
Xvid4PSP - Help
By Simmons in forum Video ConversionReplies: 11Last Post: 30th Mar 2011, 04:09 -
XviD4PSP HELP!
By jbird69 in forum Video ConversionReplies: 1Last Post: 13th May 2010, 22:45 -
XviD4PSP
By gjordan12198 in forum Video ConversionReplies: 2Last Post: 18th Dec 2008, 01:52
