Page 4 of 8
FirstFirst ... 2 3 4 5 6 ... LastLast
Results 91 to 120 of 216
  1. Originally Posted by hemstock View Post
    Try adding /r after "for" and placing the bat file in the root folder (D:\MB)
    Thanks @hemstock
    Thanks for the '/r' tip.
    Does it mean rescan subfolders?
    That will not give the desired conversion as I pointed out.
  2. Yes it goes through subfolders too.
    Im not familiar with what files cd players play I can't help you with the convertion.
  3. Originally Posted by hemstock View Post
    This is a good tip.
    Thanks.
  4. Hello,
    Taking a clue from @baldrick's example (#1 Post) and the other from @hemstock, I created a batch file with the following commands:
    for /r %%a in ("*.mpg") do "C:\ffmpeg-20151108\bin\ffmpeg" -i "%%a" -c:v libx264 -preset slow -crf 20 -c:a libvo_aacenc -b:a 128k "D:\MB\%%~na.mp4"
    pause
    It is not what I intended to do but is working as of now without any hitch and creating backup for me.
    Thanks @baldrick's and @hemstock
  5. Hi, I'm new here; I have a question:
    tengo un archivo .mkv que tiene 2 audios; inglés y español
    My question is how to convert to mp4 and choose the audio output between English or Spanish?
    currently I use the following code:
    for %%a in ("*.*") do C:\ffmpeg\bin\ffmpeg -i "%%a" -c:v libx264 -preset slow -crf 20 -c:a libvo_aacenc -b:a 128k "convert\%%~na.mp4"
    pause
  6. Originally Posted by ConverterCrazy View Post
    R for Recurse through subfolders:
    http://www.computerhope.com/jargon/r/recurse.htm
    The term comes from the way this type of code works. Typically the function handles each file in a folder calls itself (recurses) to parse each sub folder.
  7. Delete.
  8. Member bat999's Avatar
    Feb 2008
    Originally Posted by mikezz View Post
    ... MP4 format so that it is accepted by youtube...
    Hi
    Use a command like this to create one mp4 file (whatever.mp4) from one jpg file (Herringbone.jpg) and one mp3 file (filename.mp3).
    ffmpeg -loop 1 -i Herringbone.jpg -i filename.mp3 -shortest -c:v libx264 -tune stillimage -c:a copy -movflags faststart whatever.mp4
    Make sure it uploads OK to YouTube.
    Then add the extras to make a batch command, see the previous examples in this thread.
  9. Originally Posted by bat999 View Post
    Hi
    Thank you for your help.
  10. Member bat999's Avatar
    Feb 2008
    ... how to do a batch command that convert all my mp3 files into flv or mp4 while keep the same original filename with spaces. ..
    Hi
    This works as a batch command...
    for %a in ("*.mp3") do ffmpeg -loop 1 -i Herringbone.jpg -i "%a" -shortest -c:v libx264 -tune stillimage -c:a copy -movflags faststart "%~na.mp4"
    If you need to make a "batch.bat" file as in the tutorial it's like this...
    for %%a in ("*.mp3") do ffmpeg -loop 1 -i Herringbone.jpg -i "%%a" -shortest -c:v libx264 -tune stillimage -c:a copy -movflags faststart "%%~na.mp4"
    pause
  11. Originally Posted by bat999 View Post
    Hi
    pause
    WOW thank you!!!
  12. edit nevermind, got it!
  13. I'm a MEGA Super Moderator Baldrick's Avatar
    Instead of deleting your question tell us how you got it. It might help others!
    Aug 2003
    Europe
    only madmen does mkv > mp4
    alot of players these days support mkv, even my samsung ultrahd tv does it now, and the ironiy it works even better with 4k mkv than 4k mp4
    i suspect the samsung mp4 demuxer is horrible compared to samsung mkv demuxer (suspect this is either haali or the reference one)
    anyway thanks for the great article
    Jun 2016
    Poland
    Hello.
    script that i use
    for %%a in ("*.mkv") do "D:\PROGRAMY\ffmpeg\ffmpeg.exe" -i "%%a" -vf subtitles="%%a" -acodec copy -vcodec libx264 -preset medium -tune animation -crf 23  "C:\Users\DRAKO\Desktop\Nowy folder\newfiles\%%~na.mp4"
    pause
    and i want convert mkv to mp4 with .ass or .srt subtitles which are in the same folder
  16. I'm a MEGA Super Moderator Baldrick's Avatar
    Originally Posted by cartunek View Post
    Hello.
    script that i use
    pause
    I would see if mkv2mp4 supports that. To avoid any video reconversion.
    Jun 2016
    Poland
    Hello.
    script that i use
    pause
    Yeah... i need to make hardsubs because I want to watch on my TV, and my tv not support any sub styles etc... that's why i need to convert mkv to mp4 hardsub with external subtitles!
  18. Originally Posted by itzdjm View Post
    pause
    You need to add map command and language:eng? language:esp?
    https://ffmpeg.org/ffmpeg.html#Advanced-options
    To pick the English audio stream:
    ffmpeg -i INPUT -map 0:m:language:eng OUTPUT
  19. hello I have a folder with multiple avi files who all have mp3 as their audio format. I want to extract all the Audio tracks of the files at once.
    I put all the files in the bin folder off ffmpeg so they are in the same folder as "ffmpeg.exe", "ffplay.exe", "ffprobe.exe" and my bat.
    I used this command from user ********
    FOR %%i IN ("*.avi") DO (
    echo %%i
    ffmpeg -i %%i -vn -acodec copy "newfiles\%%i.mp3"
    but it doesn't work. The cmd opens, shows the code for the first file, does nothing and I can't close it anymore. I'm shure it's gone when I reboot. I would be happy if anyone knows what the right command is ?
  20. Originally Posted by Gwar View Post
    echo %%i
    You trying to pass 2 different commands at once (in one line) you may try to use & operator so perhaps this will work (not tested):
    FOR %%i IN ("*.avi") DO (echo %%i & ffmpeg -i %%i -vn -acodec copy "newfiles\%%i.mp3")
  21. Originally Posted by pandy View Post
    thanks a lot Pandy. It almost works. It just doesn' accept filenames with blanks in it and skips them.
    If ffmpeg only able to demux files with filenames which don't contain any blanks ?
    let me know
    thanks a lot
  22. Originally Posted by Gwar View Post
    let me know
    thanks a lot
    http://stackoverflow.com/questions/6376113/spaces-problem-in-cmd
  23. sorry I don't understand it at all I guess my english is too bad. Could you please help me with the command and where I have to insert quotations marks?
    thanks a lot
  24. Put quotes around %%i.
  25. works perfect now. So I summarize it for everybody:
    If you want to extract the Audio Tracks of Avi files go to the bin directory of ffmpeg, move all avi files in there, create a new folder "newfiles" and run this batch command
    FOR %%i IN ("*.avi") DO (echo "%%i" & ffmpeg -i "%%i" -vn -acodec copy "newfiles\%%i.mp3")
    thanks goes to pandy and jagabo
    cheers
    -gwar
  26. Nice guide, hoping someone can help me. I want to run a batch command to check the integrity of multiple .mp4
    This is the command for 1 file:
    ffmpeg -v error -i "File Name".mp4 -f null - >error.log 2>&1
    I cant get the batch part to work, any help would be greatly appreciated.
  27. I'm a MEGA Super Moderator Baldrick's Avatar
    Tried?
    FOR %%i IN ("*.mp4") DO  ffmpeg -v error -i "%%i" -f null - >"%%i"-error.log 2>&1
    And are you running windows?
  28. Originally Posted by Baldrick View Post
    Tried?
    Yes running windows 7 32bit
    Above command unfortunately doesn't work, command prompt returns:
    %%i was unexpected at this time.
    I've also tried:
    find . -type f -exec sh -c 'ffmpeg -v error -i "{}" -f null - > "{}".log 2>&1' \;
    It produces an error file, though it always gives the following error:
    Access denied - .
    File not found - -TYPE
    File not found - F
    File not found - -EXEC
    File not found - SH
    File not found - -C
    File not found - 'FFMPEG
    File not found - -V
    File not found - ERROR
    File not found - -I
    File not found - -F
    File not found - NULL
    File not found - -
    File not found - '
    File not found - \;
  29. This worked for me:
    for %%F in (*.mp4) do ("G:\Program Files\ffmpeg\bin\ffmpeg.exe" -v error -i "%%F" -f null - >error.log 2>&1)
    But I don't have any mp4 files with errors so error.log was empty.
  30. Originally Posted by jagabo View Post
    This worked for me:
    Thanks, but again I get the same error as with Baldrick's command. (%%F was unexpected at this time.)
    I tried updating ffmpeg to lastest build: f41e37b (2016-07-14), though still can't get it to work.
