All AVI and WAV files have same names in one folder. Using Machete, Virtualdub I can merge/mux/multiplex them one by one.
Because each file is 3gb it takes 5-6 minutes for one file. I have more than 100 files. How can i automate this? Which program can do this for me? I only need merge/mux option, nothing else.
Results 1 to 19 of 19
You can use ffmpeg.
Download ffmpeg( http://ffmpeg.zeranoe.com/builds/win32/static/ and choose a recent build). Put the ffmpeg.exe in same folder as your files.
Open notepad and put the following text
Code:for %%a in ("*.avi") do ffmpeg -i "%%~na.wav" -i "%%~na.avi" -acodec copy -vcodec copy "newfiles\%%~na.avi" pause
Create a folder newfiles in same folder as your avi files.
Double click on the batch.bat
You will see if you get any errors.
Try first with a just one avi and wav file in a folder and see how it works.
edit: I have made a detailed ffmpeg batch guide also: https://forum.videohelp.com/threads/356314-How-to-batch-convert-and-multiplex-any-files-with-ffmpegLast edited by Baldrick; 29th May 2013 at 02:25.
Thanks very much. It worked without any problem. I was looking for such a solution to automate it. Thanks again.
Now i need to convert all of these AVI files to any format. These are more than 300 gb broadcast files. Its too much 300 gb.
How can i convert these files to divx or mwv automatically? Can you help me again please? -
You could also convert directly in fffmpeg. But it's easier to use a gui-application with batch convert support like xmedia recode, video to video converter, etc.
But give more details about the source files(use mediainfo, open avi, view->text and copy everything) and how much you would like to compress them. -
You don't need to run the bat file from a command prompt. just run the .bat file.
Put the bat file and ffmpeg in the "Newfolder" and double click the bat file.
Code:for %%a in ("*.avi") do ffmpeg -i "%%~na.wav" -i "%%~na.avi" -acodec copy -vcodec copy "C:\newfolder\newfiles\%%~na.avi"
Code:for %%a in ("*.avi") do ffmpeg -i "%%~na.wav" -i "%%~na.avi" -acodec copy -vcodec copy "C:\newfiles\%%~na.avi"
Here is the file info. I have enough space, good quality is fine for me.
General
Complete name : D:\biten\00002013-02-23.avi
Format : AVI
Commercial name : DVCPRO
Format profile : OpenDML
File size : 3.17 GiB
Duration : 14mn 58s
Overall bit rate mode : Constant
Overall bit rate : 30.3 Mbps
Writing application : Lavf55.7.100
Video
Format : DV
Codec ID : dvsd
Codec ID/Hint : Sony
Duration : 14mn 58s
Bit rate mode : Constant
Bit rate : 24.4 Mbps
Encoded bit rate : 28.8 Mbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Bottom Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 2.357
Time code of first frame : 00:00:00:00
Time code source : Subcode time code
Stream size : 3.01 GiB (95%)
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Duration : 14mn 58s
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 164 MiB (5%)
Alignment : Aligned on interleaves
Interleave, duration : 21 ms (0.53 video frame) -
Just add pause
like
Code:for %%a in ("*.avi") do c:\ffmpeg\ffmpeg -i "%%~na.wav" -i "%%~na.avi" -acodec copy -vcodec copy "C:\newfiles\%%~na.avi" pause
Need Help Changing the Default Audio Stream for Hundreds of MKV Files
By ballsoup in forum AudioReplies: 11Last Post: 19th Apr 2016, 15:53 -
How to merge avi files?
By mkvelidadon in forum Newbie / General discussionsReplies: 3Last Post: 26th Sep 2011, 02:25 -
How to merge wav files ?
By Benjy in forum AudioReplies: 7Last Post: 31st Jul 2010, 04:41 -
merge two avi files
By Jorge in forum Video ConversionReplies: 4Last Post: 17th Feb 2010, 22:01 -
merge avi and wav
By zootedlooter in forum EditingReplies: 2Last Post: 21st Dec 2008, 13:11
