I have a ripped copy of A Good Day to Die Hard and I've noticed on a lot of 1080p rips they have this weird video glitching. I would like to know if it was done through the ripping process or if it's my computer (I use VLC) I don't think it's my computer because when I replay the scene it gives me the weird glitch at the same time every time.
Do you guys know what this is actually called (If there is a term for it) and how to fix it? Thanks!!
Closed Thread
Results 1 to 15 of 15
Then just play or backup your original Blu Ray disc:
http://www.amazon.com/Good-Day-Hard-Blu-ray-Combo/dp/B00BUADSMQ
...because discussing illegally downloaded material is not allowed here.
My guess would be that your player doesn't have deblocking turned on, and/or the rip suffered from insufficient bitrate. Instead of just throwing bitrate at it, you may be able to find an encoder configuration that uses existing bitrate more intelligently, thereby reducing blocking. It's just a question of how much it bugs you and how much of what you're prepared to spend fixing it.
Cheers,
Francois
General Unique ID : 195725742586832119146374986003462715241 (0x933F68278DBC01FEA89652664F8B7769) Complete name : C:\Users\Csmith\Downloads\A Good Day to Die Hard\A Good Day to Die Hard.mkv Format : Matroska Format version : Version 4 / Version 2 File size : 4.35 GiB Duration : 1h 41mn Overall bit rate : 6 157 Kbps Movie name : A Good Day to Die Hard 2013 Encoded date : UTC 2013-05-26 07:01:09 Writing application : mkvmerge v6.2.0 ('Promised Land') built on Apr 28 2013 12:22:01 Writing library : libebml v1.3.0 + libmatroska v1.4.0 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1h 41mn Bit rate : 5 200 Kbps Width : 1 280 pixels Height : 688 pixels Display aspect ratio : 1.85:1 Frame rate mode : Constant Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.246 Stream size : 3.59 GiB (82%) Title : A Good Day to Die Hard 2013 Writing library : x264 core 130 r2273 b3065e6 Encoding settings : cabac=1 / ref=4 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=18 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=5200 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00 Language : English Default : Yes Forced : No Audio ID : 2 Format : DTS Format/Info : Digital Theater Systems Mode : 16 Format settings, Endianness : Big Codec ID : A_DTS Duration : 1h 41mn Bit rate mode : Constant Bit rate : 960 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Compression mode : Lossy Stream size : 695 MiB (16%) Title : A Good Day to Die Hard 2013 DTS 5.1 Language : English Default : Yes Forced : No Text #1 ID : 3 Format : VobSub Codec ID : S_VOBSUB Codec ID/Info : The same subtitle format used on DVDs Title : A Good Day to Die Hard 2013 English (Foreign Only) VobSub Language : English Default : Yes Forced : No Text #2 ID : 4 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Title : A Good Day to Die Hard 2013 English (Foreign Only) Srt Language : English Default : No Forced : No Menu 00:00:00.000 : en:00:00:00.000 00:02:45.999 : en:00:02:45.999 00:05:02.135 : en:00:05:02.135 00:09:36.242 : en:00:09:36.242 00:12:13.900 : en:00:12:13.900 00:15:25.550 : en:00:15:25.550 00:18:02.999 : en:00:18:02.999 00:22:31.350 : en:00:22:31.350 00:28:31.376 : en:00:28:31.376 00:32:28.863 : en:00:32:28.863 00:36:05.914 : en:00:36:05.914 00:39:53.641 : en:00:39:53.641 00:42:20.621 : en:00:42:20.621 00:46:04.720 : en:00:46:04.720 00:50:30.986 : en:00:50:30.986 00:53:21.657 : en:00:53:21.657 00:57:05.547 : en:00:57:05.547 01:01:46.619 : en:01:01:46.619 01:05:03.650 : en:01:05:03.650 01:10:24.053 : en:01:10:24.053 01:14:04.982 : en:01:14:04.982 01:17:50.416 : en:01:17:50.416 01:20:18.021 : en:01:20:18.021 01:24:05.832 : en:01:24:05.832 01:26:17.923 : en:01:26:17.923 01:28:05.488 : en:01:28:05.488 01:32:37.802 : en:01:32:37.802 01:35:24.927 : en:01:35:24.927
I fail to see where I talked about downloading a movie from a filehost or torrent. My brother obtained a bluray copy and ripped it. Put it on a skydrive and wanted me to watch it to let him know if there was anything wrong with it. So I was asking for help on a video glitching error. Am I missing something?Code:
Warez rules What is warez? Obtained movies/tv-series/tv-shows/software either through download, torrent, etc that breaks the copyright. Do NOT talk about warez releases Like filenames Movie.2012.DVDSCR.X264.AAC.P2P.mkv. Please don't download warez movie/tv releases. Do NOT talk about copying rented material You are not allowed to rip/copy/record rented video. It includes streaming rented video like netflix, itunes, hulu plus, etc. Do NOT give warez / Do NOT link to warez Distributing warez. This includes linking to warez either directly or to crack or serial sites. Offering warez in any fashion including PM or e-mail is against forum policy. Do NOT ask for warez Asking for warez. In any fashion this is unacceptable including but not limited to PM or e-mail requests or information on what p-2-p network has copies. Do NOT provide information on how to obtain warez Providing information on how to obtain warez. Do NOT advocate warez Advocate warez. Recommending the use of warez.
This is not deblocking problem and your bitrate necessary. This is color conversion problem. Try uncheck Preferences > Video > Accelerated video output (Overlay) and Use hardware YUV->RGB conversion.If not change, change media player.KMPlayer with "K-Lite Codec Pack > LAV Video Decoder" (Free) or "Splash Pro" (Commercial) is good media players.
The KMPlayer seems to have fixed it! Thank you Hikmet for actually helping me!
Understanding how to use in combination with program called movie fix
By EDDIECRUZ in forum Newbie / General discussionsReplies: 4Last Post: 25th May 2012, 08:29 -
What is this called and how do I fix it?
By jarlaxle in forum Newbie / General discussionsReplies: 5Last Post: 28th Feb 2012, 04:08 -
Guys, How can I work with TS files? (Picture inside)
By AsemPlus in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2012, 06:49 -
How to embed a video in a Picture ??? example inside
By momo1984 in forum Newbie / General discussionsReplies: 2Last Post: 24th Mar 2011, 11:13 -
What is it called and how to fix it? (from an old video)
By namphong0612 in forum EditingReplies: 5Last Post: 18th Sep 2010, 20:19
