I have a subtitled MKV video. It plays fine on my computer, but I want to play it my iPad. The iPad doesn't natively play MKV video.
MKVtoonix is a good Mac app to deal with processing, but my results were poor. I used Jubler to render the subs, but the ASS subs i ended up with didn't work well; the text was gobbledygook.
In other words, my next step is to convert my MKV/ASS subs to SRT before I progress anywhere, but my Mac tools don't seem to be able to do this.
Any ideas?
Results 1 to 11 of 11
Most of the time it's a bad idea to convert ass to srt since you will loose nearly all formatting information (only one font, nol animations&co), especially if you aim to create a mp4/m4v in the end the subtitle have to become ttxt subtitle and nearly no fonts are supported by most devices for ttxt.
-> the best solution would be to look for a player which supports mkv with ass subtitle on the iPad (got no iPad, so no clue if one exists)
That aside, Hybrid (runs n Mac/Linux/Windows) should be able to remux mkv -> mp4 and adjust the subtitles.
- start Hybrid
- load source
- enable Config->Automation->Passthrough->Video->Subtitle
- set "Main->Primary Input Selection->Video handling" to "passthrough"
- set "Main->Primary Input Selection->Audio handling" to "passthrough all"
- set the output
- enable Config->Internals->Output->Container Settings->Mp4 Settings->iTunes compatibility
- press "Main->Add to Queue" (right corner)
- press "Main->Start Queue" (right corner)
pro: subtitles with all effects&co stay there
con: reencoding takes a lot of time and lowers the quality
Cu SelurLast edited by Selur; 27th May 2013 at 02:39.
I'd never heard of Hybrid before (despite intensive searching) - and it looks very promising. Thanks for the concise and accurate instructions, too; while the application isn't intuitive, your instructions were very clear and accurate.
Hybrid works very well, but it seems that, somewhere in the encoding process, the subtitles can be lost. (In other words, it may be necessary to add the subtitles in an later step.)
But here's the issue: .mkv documents are composed of video, audio, and subtitle files. There's no problem if there's only video and audio; however, subtitle files are frequently .ass documents. This is the step when the subtitles disappear after processing. That may be what's happening here. -
argh,.. I made a mistake with the order of the instructions:
- start Hybrid
- load source
- set the output
If this also doesn't work try:
- start Hybrid
- load source
- enable Main->Primary Input Selection->All subtitles
- press 'Add&Extract Subtitles' (the '+', next to the 'all subtitles'-checkbox)
- set the output
Cu Selur -
For some reason, the subtitles aren't being generated, even with the new version of Hybrid. I came up with error(s) that may have stopped further processing:
"Cannot find file /var/folders/kq/x7pnrcyn2g5_p6m_qr826mn80000gn/T/Girls und Panzer_10_07_57_2910_02.264
Error importing /var/folders/kq/x7pnrcyn2g5_p6m_qr826mn80000gn/T/Girls und Panzer_10_07_57_2910_02.264#video:fps=23.976: Requested URL is not valid or cannot be found
find file /var/folders/kq/x7/"
On the second input procedure, at:
"5. "enable Main>Primary Input Selection>All subtitles"
…the subtitle field is grayed out, and there's no way to activate the (+) checkbox.
Thanks again for your intensive help with this challenge! -
You need to close and open Hybrid before you try the second way. If subtitles were detected and the 'Automation...'-part is not active the All subtitles and '+' should not be grayed out.
About the missing file:
Enable debugOutput (Config->Internals->Create debug file, level 4') reproduce the problem and attach the HybridDebugOutput.txt which should be in the output folder. -
I went through several procedures, but using the last, I generated the debug text:
2013.05.27 - 11:34:26_Mac OS X-64bit_4.8.0_2013.05.22.1 - Saved x264Model, base version: 130423
2013.05.27 - 11:35:32_Mac OS X-64bit_4.8.0_2013.05.22.1 - stopping preview,...
2013.05.27 - 11:35:32_Mac OS X-64bit_4.8.0_2013.05.22.1 - Closing Previews,..
2013.05.27 - 11:41:37_Mac OS X-64bit_4.8.0_2013.05.22.1 - Saved x264Model, base version: 130423
2013.05.27 - 11:42:25_Mac OS X-64bit_4.8.0_2013.05.22.1 - Saved x264Model, base version: 130423
2013.05.27 - 11:42:26_Mac OS X-64bit_4.8.0_2013.05.22.1 - Saved x264Model, base version: 130423
2013.05.27 - 11:42:39_Mac OS X-64bit_4.8.0_2013.05.22.1 - Loading GlobalDataModel,...
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - Loading x264Model,...
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - get file name: /Users/stevenspinali/Desktop/Girls und Panzer.mp4
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - getWholeFileName: Girls und Panzer.mp4
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - -> file name: Girls und Panzer
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - There's no timecode in mkv_deb1536f480475f7d593219aa1afd74c_16807
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - converting decimal to fraction: 23.97600000
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - -> fraction: 23976/1000
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - /Users/stevenspinali/.hybrid/profiles/video/x264/x264 Hybrid Default.xml already exists -> nothing to do,...
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - Loading cudaH264Model,...
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - /Users/stevenspinali/.hybrid/profiles/video/cudaH264/cudaH264 Hybrid Default.xml already exists -> nothing to do,...
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - Loading xvidModel,...
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - /Users/stevenspinali/.hybrid/profiles/video/xvid/xvid Hybrid Default.xml already exists -> nothing to do,...
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - Loading VP8Model,...
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - /Users/stevenspinali/.hybrid/profiles/video/vp8/vp8 Hybrid Default.xml already exists -> nothing to do,...
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - Loading ProResModel,...
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - Loading FilteringModel,...
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - Loading SubtitleModel,...
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - Loading AudioModel,...
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - Adjusting to current audio...
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - audio count in audio container: 1
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - show current audio infos,..
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - There's no Language in mkv_deb1536f480475f7d593219aa1afd74c_1622650073
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - There's no Dialog Normalization in mkv_deb1536f480475f7d593219aa1afd74c_1622650073
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - Ignoring 'addCurrentAudioToList while updating',...
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - Loading TagModel,...
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - Loading ChapterModel,...
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - Loading JobManagerModel,...
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - Loading MainTabModel,...
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - selectSubtitle with index: 0
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - setting currentSubtitleTitle to: 1 - und
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - emmiting subtitle index: 0
2013.05.27 - 11:42:40_Mac OS X-64bit_4.8.0_2013.05.22.1 - Loading MuxingModel,...
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - get file name: /Users/stevenspinali/Desktop/Girls und Panzer.mp4
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - getWholeFileName: Girls und Panzer.mp4
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - -> file name: Girls und Panzer
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - There's no timecode in mkv_deb1536f480475f7d593219aa1afd74c_16807
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - converting decimal to fraction: 23.97600000
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - -> fraction: 23976/1000
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - setting home dir,..
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - setting cpu count,..
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checking tools,..
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - .Net 4.x+ is present: false
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: ffmpeg, varName: ffmpeg
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile setting ffmpeg to /Applications/Hybrid.app/Contents/MacOS/ffmpeg
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: x264, varName: x264
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile setting x264 to /Applications/Hybrid.app/Contents/MacOS/x264
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: mplayer, varName: mplayer
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile setting mplayer to /Applications/Hybrid.app/Contents/MacOS/mplayer
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: mencoder, varName: mencoder
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile setting mencoder to /Applications/Hybrid.app/Contents/MacOS/mencoder
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: mediainfo, varName: MediaInfo
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile setting MediaInfo to /Applications/Hybrid.app/Contents/MacOS/mediainfo
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: mkvmerge, varName: mkvmerge
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS/Mkvtoolnix.app/Contents/MacOS, file: mkvmerge, varName: mkvmerge
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile setting mkvmerge to /Applications/Hybrid.app/Contents/MacOS/Mkvtoolnix.app/Contents/MacOS/mkvmerge
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: mkvextract, varName: mkvextract
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS/Mkvtoolnix.app/Contents/MacOS, file: mkvextract, varName: mkvextract
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile setting mkvextract to /Applications/Hybrid.app/Contents/MacOS/Mkvtoolnix.app/Contents/MacOS/mkvextract
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: mkvinfo, varName: mkvinfo
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS/Mkvtoolnix.app/Contents/MacOS, file: mkvinfo, varName: mkvinfo
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile setting mkvinfo to /Applications/Hybrid.app/Contents/MacOS/Mkvtoolnix.app/Contents/MacOS/mkvinfo
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: tsMuxeR, varName: tsMuxeR
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile setting tsMuxeR to /Applications/Hybrid.app/Contents/MacOS/tsMuxeR
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: MP4Box, varName: MP4Box
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile setting MP4Box to /Applications/Hybrid.app/Contents/MacOS/MP4Box
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: mp4fpsmod, varName: mp4fpsmod
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile setting mp4fpsmod to /Applications/Hybrid.app/Contents/MacOS/mp4fpsmod
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: sox, varName: sox
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile setting sox to /Applications/Hybrid.app/Contents/MacOS/sox
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: avsInfo, varName: avsInfo
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: oggenc, varName: oggenc
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: oggenc2, varName: oggenc
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile setting oggenc to /Applications/Hybrid.app/Contents/MacOS/oggenc2
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: aften, varName: aften
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile setting aften to /Applications/Hybrid.app/Contents/MacOS/aften
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: dcaenc, varName: dcaenc
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile setting dcaenc to /Applications/Hybrid.app/Contents/MacOS/dcaenc
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: opusenc, varName: opusenc
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile setting opusenc to /Applications/Hybrid.app/Contents/MacOS/opusenc
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: lame, varName: lame
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile setting lame to /Applications/Hybrid.app/Contents/MacOS/lame
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: delaycut, varName: delaycut
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS/delaycut.app/Contents/MacOS, file: delaycut, varName: delaycut
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile setting delaycut to /Applications/Hybrid.app/Contents/MacOS/delaycut.app/Contents/MacOS/delaycut
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: FrameCounter, varName: FrameCounter
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile setting FrameCounter to /Applications/Hybrid.app/Contents/MacOS/FrameCounter
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: vpxenc, varName: vpxenc
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile setting vpxenc to /Applications/Hybrid.app/Contents/MacOS/vpxenc
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: lsdvd, varName: lsdvd
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile setting lsdvd to /Applications/Hybrid.app/Contents/MacOS/lsdvd
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: faac, varName: faac
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile setting faac to /Applications/Hybrid.app/Contents/MacOS/faac
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: FLVExtractCL, varName: FLVExtractCL
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile setting FLVExtractCL to /Applications/Hybrid.app/Contents/MacOS/FLVExtractCL
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: bdsup2sub++, varName: bdsup2sub++
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: BDSup2Sub, varName: bdsup2sub++
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: FLACCL, varName: flaccl
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: CUETools.FLACCL.cmd, varName: flaccl
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /Applications/Hybrid.app/Contents/MacOS, file: telxcc, varName: telxcc
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile setting telxcc to /Applications/Hybrid.app/Contents/MacOS/telxcc
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /usr/bin, file: avsInfo, varName: avsInfo
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /usr/bin, file: bdsup2sub++, varName: bdsup2sub++
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /usr/bin, file: BDSup2Sub, varName: bdsup2sub++
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /usr/bin, file: FLACCL, varName: flaccl
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /usr/bin, file: CUETools.FLACCL.cmd, varName: flaccl
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /bin, file: avsInfo, varName: avsInfo
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /bin, file: bdsup2sub++, varName: bdsup2sub++
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /bin, file: BDSup2Sub, varName: bdsup2sub++
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /bin, file: FLACCL, varName: flaccl
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /bin, file: CUETools.FLACCL.cmd, varName: flaccl
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /usr/sbin, file: avsInfo, varName: avsInfo
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /usr/sbin, file: bdsup2sub++, varName: bdsup2sub++
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /usr/sbin, file: BDSup2Sub, varName: bdsup2sub++
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /usr/sbin, file: FLACCL, varName: flaccl
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /usr/sbin, file: CUETools.FLACCL.cmd, varName: flaccl
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /sbin, file: avsInfo, varName: avsInfo
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /sbin, file: bdsup2sub++, varName: bdsup2sub++
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /sbin, file: BDSup2Sub, varName: bdsup2sub++
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /sbin, file: FLACCL, varName: flaccl
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /sbin, file: CUETools.FLACCL.cmd, varName: flaccl
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /usr/local/bin, file: avsInfo, varName: avsInfo
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /usr/local/bin, file: bdsup2sub++, varName: bdsup2sub++
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /usr/local/bin, file: BDSup2Sub, varName: bdsup2sub++
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /usr/local/bin, file: FLACCL, varName: flaccl
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /usr/local/bin, file: CUETools.FLACCL.cmd, varName: flaccl
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /usr/X11/bin, file: avsInfo, varName: avsInfo
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /usr/X11/bin, file: bdsup2sub++, varName: bdsup2sub++
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /usr/X11/bin, file: BDSup2Sub, varName: bdsup2sub++
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /usr/X11/bin, file: FLACCL, varName: flaccl
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - checkFile, path: /usr/X11/bin, file: CUETools.FLACCL.cmd, varName: flaccl
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - Missing avsInfo got ignored,.. (only needed for avisynth input)
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - Gimmick components are missing:
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - - <b>flaccl</b> (used for gpu supported flac encoding) - <b>BDsub2sup++</b> (used to convert Blu-ray to DVD subtitle)
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - If you want to use one of them, you can:
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - - specify where to find the tool(s) (Config->Tools)
- save settings (Config->Defaults->Save->GlobalModel and hit 'Selected')
- restart Hybrid
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - some tools are missing,..
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - Saved GlobalDataModel, base version: 130515
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - -> there's no path specified for atm.
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - vfwDecoders should be empty:
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - avisynthAvailable should be false: false
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - updating tool versions,...
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - -> removing neroAAcEnc support,...
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - audio tab removeneroAacEnc
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - -> removing qaac & fhgaacenc support,...
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - audio tab removeqaacAndFhgAac
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - audio tab removefhgaacenc
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - audio tab removefdkaac
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - -> removing fdk-aac support,...
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - audio tab removeflaccl
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - -> removing support for flac encoding through flaccl,...
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - -> removing support for bdsup2sub++
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - initiating extractors,...
2013.05.27 - 11:42:43_Mac OS X-64bit_4.8.0_2013.05.22.1 - Successfully loaded x264Model.
2013.05.27 - 11:42:54_Mac OS X-64bit_4.8.0_2013.05.22.1 - stopping preview,...
2013.05.27 - 11:42:54_Mac OS X-64bit_4.8.0_2013.05.22.1 - Closing Previews,..
I'd be happy to include other information you request. Thanks for your continued for help! -
please edit your post and at least use 'code'-tags or attac a debug output, atm. it's no confort at reading,...
+ seems like I broke the debug output in my testing version, need some time fixing it
In the meantime, I've been investigating other ways of addressing this challenge. I found this link:
http://forums.macrumors.com/showthread.php?t=1056023
This addresses the problem exactly. The application is MP4Tools, a cheapware program that can solve the import of mkv files into the iPad. After playing around with the application, I found out that it worked, albeit not terribly quickly - but it's probably a realistic speed, since going from mkv to mp4 is a little more involved than simply a file conversion. Count on at least thirty minutes for a half-hour file
So far, it's the only application that can - at least yet - reliably convert mkv to mp4 on the Mac. -
The debug issue seems to have broken at least one machine!
I've started using MP4Tools. Not exactly slick, but it's handled just about everything I've thrown at it. Surprisingly, MP4Tools seems to be the only software out there for the Mac that converts .mkv to .mp4 while handling those pesky .ass files.
If you only have .srt files to contend with, you'll do just fine with something like Handbrake.
Help with avi/mkv conversion to vob with enabled italic subtitles
By hibbs in forum Newbie / General discussionsReplies: 0Last Post: 2nd Oct 2011, 22:18 -
MKV conversion with subtitles
By losernoob in forum Video ConversionReplies: 0Last Post: 16th Oct 2010, 23:20 -
Need Help on XviD4PSP (Conversion of MKV to AVI, subtitles SPU codec)
By gallen16 in forum Video ConversionReplies: 3Last Post: 10th Oct 2010, 11:44 -
Subtitles cutoff in MKV to DVD conversion
By kinghlg in forum SubtitleReplies: 3Last Post: 17th Mar 2009, 16:44 -
Conversion of MKV subtitles to DVD
By BillinToronto in forum Video ConversionReplies: 3Last Post: 24th Jul 2008, 09:36
