Is it possible to rip a region2 PAL DVD and then convert it to svcd (to play back in widescreen NTSC?).
I'd like to experiment with this, but I was just wondering if anyone has done it. There are several European DVDs I'd like to purchase and would rather not spend the money for a codefree player AND a converter (we're talking $800+ just to watch a $30 DVD).
If it is possible, should I use DVD2SVCD and TMPG?
Thanks,
Bob
Yes, First rip it with smart ripper then use dvd2avi then use Tmpg you should use ntsc template in Tmpeg. that is it
DVD2SVCD does that conversion quite nicely -- but you might be interested to know that your DVD player will play PAL and NTSC SVCD's just fine.
It's only with DVD's that there is a problem with the two formats - create a small SVCD and test it - I'm sure it will work
so you just need to convert it to SVCD and probably best to leave it as PALyour pal,
Stinky
Playing a Region2 dvd on a Region1 Player
By barbudo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 17th Feb 2011, 09:48 -
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 21:53 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 17:46 -
PAL SVCD - Optimal resolution for preserved aspect ratio?
By Gew in forum Authoring (VCD/SVCD)Replies: 7Last Post: 27th Feb 2009, 15:25 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18
