When I convert camcorder DV AVIs to MP4 using AviDemux, I'm getting really bad camera shake jerkiness. The output looks erratic and unpleasant to watch compared to the source AVI when watched on a TV.
BTW, the problem is just as bad whether I deinterlace or not (using Yadif).
Thanks for any tips!
Chris
Did you select yadif order=0, mode=1 ? This "bob deinterlaces" to double framerate 59.94p instead of 29.97p
mode=0 => single rate
mode=1 => double rate -
I set Yadif to Spatial and Temporal (no bob) and BFF. So the content went from 60 fields to 30 progressive frames per sec, which naturally could add some herky-ness. I also tried it interlaced, but it looked practically identical, and I thought I was careful to maintain the interlace properly (nothing moved backwards, etc, and the x264 encoder was set to interlaced BFF for that experiment).
I'll probably have time to upload clips tomorrow. The thing is, the problem is worst when I play them back on a TV uploaded to my TiVo box. Subtle on the PC. I was just looking for pointers on x264 settings. I wouldn't consider this a 'problem' to 'troubleshoot.'
I'm wondering if this issue with processed DV is at all related to my similar issue with processed HDV. My HD home movies when converted to MP4 also can get herky-jerky, and the entire frame will stay frozen between fields even though the camera is panning, and so a kid's arm will be the ONLY motion on the whole screen when stepping single-frame--as if the arm is an animation overlaid on a still background image. I'd prefer less efficient encoding and more analog behavior.
But in the HDV case, it's not even noticeable at full speed on a TV, unless paused and single-stepping. The problem with DV video is hard on the brain at normal playback, not just a peculiarity.
I really appreciate the replies!
Chris -
Other than the field order setting, which you've already accounted for, there aren't any x264 settings that would cause a video to get shaky.
That sounds more like an error decoding the source. Or maybe you're using settings too CPU intensive for realtime playback on whatever device you're using (not all devices support all h.264 features).
Just as a reference, the video in the following link shows the difference between 60p and 30p (and 24p) on a 60 Hz display:
https://forum.videohelp.com/threads/307004-Best-framerate-conversion-%28eg-23-97-to-30-...=1#post1888926
It's an Xvid AVI but the issue is the same no matter what codec is used.
How to fix screen shake with Avisynth?
By VideoFanatic in forum RestorationReplies: 2Last Post: 23rd Apr 2013, 11:56 -
How to Remove Camera Shake from iPhone 4S Videos (Batch Deshaker Script)
By preshing in forum EditingReplies: 1Last Post: 17th Apr 2012, 22:35 -
Reducing Camera shake in post production
By Dannyboy125 in forum Newbie / General discussionsReplies: 7Last Post: 16th Sep 2011, 07:42 -
Seeking for some easy tool to convert camera video to x264
By junglemike in forum Newbie / General discussionsReplies: 2Last Post: 9th Jun 2009, 06:03 -
Remove some shake from video
By helper in forum Newbie / General discussionsReplies: 1Last Post: 6th Oct 2008, 14:39
