I'm using Handbrake to shrink an MKV file
It's reporting that it's going to take 7 hours or something close to convert to MP4
(Using a Dual Core P2.5 Dell laptop)
I've just left it running
Question: would it be quicker to convert to MKV or MP4?
OM
Is this h264?
Mkv and mp4 are just containers. They hold the video.
Are you going to 1080p video? It might be quicker to go to 720p video at a bit of a quality hit.
Also are you doing more than 1 pass? Are you adding filters to it to change the video?
What is your source?
You see there is a lot that goes into deciding how long it takes to make a video file.
Also don't have anything running while you're doing it either - except for antivirus of course. You should have your system as free for just video as possible.
And you should be going from internal drive to internal drive or your destination should be on the same drive. If you are converting over to a usb or external drive that will add to the time too.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
demux MKV and remux to MP4, but without reducing the sizeQuestion: would it be quicker to convert to MKV or MP4?
thanks for the replies guys
the file would typically be 720p blu ray rip
so h264
that's all i know
the file size needs to be smaller so i can play on my android phone while running on a treadmill at the gym
i find it hard to get hold of a divx version - which i would do otherwise (but i still have to resize to ensure smooth playback - else it's jumpy)
does that change anything?
thanks
MkvТоMp4 v0.224 - rapid tool for repack Mkv to Mp4
By oreons in forum Video ConversionReplies: 808Last Post: 7th Mar 2022, 02:43 -
MKV Compression to a smaller MKV or MP4
By THRobinson in forum Video ConversionReplies: 9Last Post: 20th Jul 2018, 11:56 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 03:45 -
muxing .264 stream to .mkv, or to .mp4 first, an then to .mkv ?
By codemaster in forum Video ConversionReplies: 2Last Post: 20th Sep 2011, 21:50
