This under $10 device is called a USB to audio adapter:
http://www.newegg.com/Product/Product.aspx?Item=N82E16812186035
Also can be used to make phone calls. Provides 2 mic level software adjustments:
One for mic volume to person at other end of the line, another for mic volume to hear yourself in earphone (commonly called "sidetone"), but default adjustment is fine (plug and play).
USB audio device have been around for a long time. Starting withe expensive devices like the Creative Labs Sound Blaster Audigy 2 NX back in ~2002. The original idea was to get the audio circuitry outside the electrically noisy computer case to improve signal to noise ratio.
Looking for Low Cost (Cheap) Stock Footage for Editing Production
By HoosierGuy in forum EditingReplies: 3Last Post: 13th Feb 2012, 06:07 -
Looking for low cost editor that can make multiple cuts and splice
By jimdagys in forum EditingReplies: 4Last Post: 11th Dec 2011, 12:33 -
Do I need a NLE & Is there a free/low cost one available?
By TBoneit in forum EditingReplies: 2Last Post: 17th Sep 2010, 12:08 -
Is nvidia 3d a low cost way to 3dtv?
By yoda313 in forum ComputerReplies: 6Last Post: 3rd Jul 2010, 01:35 -
Why can I get a low cost learning remote ?
By SingSing in forum Newbie / General discussionsReplies: 7Last Post: 27th Mar 2010, 20:35
