in SD I alwais uded the old In Sync Speed Razor 5.51 software but now I converted to the HD and Speed Razor does not exist.
It had nice things: infinite layer compositing (not an A/B roll); Editing as language; Effects with controls right on the image (this came out of my use of 3d tools) ecc..
but now I work with a Sony PDW-F800 Xdcam Hd 422 camera
what is the best nle to edit with .mxf files that resembling as much possibile to Speed Razor?
however is possible to have the infinite layer caratherics as Speed Razor?
thanks to all
To edit the camera files you need a big-boy NLE like Avid Media Composer, Premiere Pro, FCP(X), or Sony Vegas Pro. You want to maintain the entire structure of the disk or card, not simply extract individual mxf files in order to retain metadata and manage spanned clips.
Sony's content browser software gives you some imited ability to trim and convert clips, but it is not intended to be an NLE. -
Hi, now I'm trying Avid MC 5.5 but I heard audio jerky.
Do you know if I have to configure?
thanks -
Avid's got some pretty high system specifications which it sounds like you may not be meeting. http://avid.force.com/pkb/articles/en_US/compatibility/en267087
Vegas is a little more forgiving.
i don't recall whether that camera records 4 or 8 tracks of uncompressed audio.
How to import Sony XDCAM EX files to FCP?
By vivian58 in forum MacReplies: 2Last Post: 31st Aug 2012, 10:16 -
Frameserving from Sony Vegas into MXF format
By 24fps in forum Video ConversionReplies: 5Last Post: 8th Feb 2012, 08:57 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
MXF XDCAM HD 422 loses stereophony?
By elmuz in forum Video ConversionReplies: 0Last Post: 2nd May 2011, 05:29 -
xdcam to .mov so I can edit with iMovie????
By boriega in forum Video ConversionReplies: 3Last Post: 15th Sep 2010, 00:39
