hello,
i just found this forum via google and found it very helpful, so i believe i will get the help from you guys.
i have samsung LED tv and i play movies and video songs on it, unfortunately it does not support mkv profile 4 or higher format and i have some important files/videos to play,
so how can i convert mkv profile 4 video to mkv profile 2 or 3 and retain the same HD 1080p quality?
Thanks in advanced.
Results 1 to 9 of 9
mkv version 4???
Or do you mean h264/avc levels? See https://en.wikipedia.org/wiki/H.264/MPEG-4_AVC#Levels -
No such thing. MKV has no profiles or levels. Only the h264/avc video codec.
what?? are you sure? sorry i'm newbie.
i think the correct word to use is Format version
see the relevant question here
https://forum.videohelp.com/threads/322184-How-can-I-convert-MKV-profile-high-5-1-to-MKV-profile-4-1 -
Yep, it's the h264 level.
But most players supports 4.1. What is the led tv model?
Maybe easiest to reconvert to avi divx/xvid with something like video to video converter, freemake video converter. -
Try opening one of the files it won't play using MKVMergeGUI (one you're certain is high profile, level 4.1). Start off by unchecking everything except the video and audio streams. Look under the attachments tab. If there's any attachments listed, de-select them. Save that as a new MKV and see what happens hwne you try to play it.
My Samsung TV doesn't seem to be all that crazy about some types of attachments. It says "unsupported format".... or something to that effect..... until I delete them.
Just something to try..... -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 03:45 -
Best quality option to convert 1080p mkv to 720p mkv
By carlmart in forum Video ConversionReplies: 5Last Post: 14th Mar 2010, 08:17 -
How to convert mkv to ps3 viewable format maintaining mkv subs in new file?
By shuyinliquid in forum Video ConversionReplies: 2Last Post: 14th Dec 2009, 02:17 -
convert mkv to avi with the same quality. How ?
By SB4 in forum Video ConversionReplies: 10Last Post: 30th Jan 2009, 07:26
