Results 1 to 12 of 12
    May 2013
    Romania
    Every time when i load a video in avidemux the sound has disspear why?
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    The video is actually a virus?
    May 2013
    Romania
    NO , the video is from sony vegas after i render it i want to load it in avidemux to add subs
    May 2013
    Romania
    And also when i click on save as , when is render i see AUDIO : 0 MB lol but when i finish the render in sony vegas the video have audio...
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Well that is a bit more information.....keep going.
    May 2013
    Romania
    What you mean? how to fix it
    Mar 2011
    Nova Scotia, Canada
    He means if anyone can fix it you'll have to give them more information. Is this just happening with one video? Does the audio work in just vegas or can vlc play it?
    Open the file from vegas with mediainfo. Post output here in text mode.
    May 2013
    Romania
    In vegas the audio work , vlc can play it too
    About mediainfo :
    http://postimg.org/image/t7qd19b8r/
    Mar 2011
    Nova Scotia, Canada
    I said post it in mediainfo text mode. Easy mode doesn't tell you enough.
    Please just copy and paste the text output into your post next time.
    May 2013
    Romania
    Is that's it?
    eneral
    Complete name : C:\Users\\Documents\Vegas Movie Studio HD Platinum 11.0 Projects\Untitled.wmv
    Format : Windows Media
    File size : 227 MiB
    Duration : 17mn 42s
    Overall bit rate mode : Constant
    Overall bit rate : 1 788 Kbps
    Maximum Overall bit rate : 3 173 Kbps
    Encoded date : UTC 2013-05-25 06:06:53.577
    SfOriginalFPS : 300000
    Video
    Format : VC-1
    Format profile : MP@ML
    Codec ID : WMV3
    Codec ID/Info : Windows Media Video 9
    Codec ID/Hint : WMV3
    Description of the codec : Windows Media Video 9
    Duration : 17mn 42s
    Bit rate mode : Constant
    Bit rate : 3 050 Kbps
    Width : 640 pixels
    Height : 360 pixels
    Display aspect ratio : 16:9
    Frame rate : 30.000 fps
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.441
    Stream size : 386 MiB
    Language : English (US)
    Audio
    Format : WMA
    Format profile : Pro
    Codec ID : 162
    Codec ID/Info : Windows Media Audio
    Description of the codec : Windows Media Audio 10 Professional - 96 kbps, 44 kHz, 2 channel 16 bit (A/V) 1-pass CBR
    Duration : 17mn 42s
    Bit rate : 96.0 Kbps
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Bit depth : 16 bits
    Stream size : 12.2 MiB (5%)
  11. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Of all of the choices you have as output formats in Vegas....you pick WMV?
    BIG mistake.
    May 2013
    Romania
    BIG mistake.
    Well what type of file i need to render from vegas to have audio in avidemux?
