I am looking to invest in an HD camcorder after many years of recording and editing SD footage of sporting events.
Would my computer be able to handle this? Its specs:
Windows 7
Intel Core i3 2.1 GHz
6 GB RAM
500 GB HDD
Would I still be able to use Premiere Elements 10?
Which HD file type would be easiest to edit? MP4?
Would I be able to export the finished videos as .f4v files without losing any quality?
Roughly what file size would a finished 10 minute video be?
Thanks for any/all advice.
Lossless AVI. If use Windows, use "CamStudio Lossless Codec". Fast and result file is small.Which HD file type would be easiest to edit? MP4?
For 720p 200-300 MB, For 1080p 400-500 MB (when encode H264/AVC)Roughly what file size would a finished 10 minute video be?
And your system is enough for HD capture... -
Can you suggest any HD cams that output files in lossless AVI?
Or would I need to convert the files to AVI? (If so, how easy/time consuming is this?)
Cheers. -
Yes, it should. Some will probably suggest a better CPU because of the longer render times that youīll probably face working with HD.
Iīd strongly suggest adding a second large and fast HDD just for video files.
You can check your program documentation to find what formats does it accept.Would I still be able to use Premiere Elements 10?
MP4 is not very edit-friendly unless your NLE accepts such files natively, even in such case its not a bad idea to transcode to something that will be easier to handle within Premiere, a lossless avi codec would be ok. Iīm not familiar with the one suggested before but also you can check lagarith, HuffYUV or UT Video Codec Suite (free) or Cineformīs NeoScene (not free), there are many threads in this site that discuss their use (but the files produced with these codecs will be very large tho)Which HD file type would be easiest to edit? MP4?
I donīt know of any that outputs to it, well maybe higher end like the RED line of digital cinema cameras with their own codec or something like that, but I donīt think thatīs what you have in mind.Can you suggest any HD cams that output files in lossless AVI?
AVCHD camcorders are popular (even if they output in .mp4, .mov, mts or other containers), decide what features you want/need and how much youīd like to spend. Converting AVCHD to lossless shouldnīt be too difficult or time consuming, again, search and read some threads on the subject. -
Adobe premiere can open mp4. But, if only want basic edit your videos, no need conversion. But you need high-end editing, complicate project then: Convert your video to lossless AVI.
If you want color grading/balance, effect vs., then: Convert your video to image sequence (.PNG)
Lossless AVI files very big and usually camcorder not support this formats.
Advice Needed on Editing Different File Types Together
By jaydub in forum EditingReplies: 2Last Post: 8th Apr 2013, 17:36 -
Video and remote controllable music for a drummer ADVICE NEEDED
By Mark97213 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jan 2013, 00:36 -
Help / 2nd opinion / advice needed from video experts - See attached Images
By sanchopanza in forum Video ConversionReplies: 5Last Post: 18th Mar 2011, 15:22 -
Video content for mobile devices: advice needed
By spycam in forum Newbie / General discussionsReplies: 7Last Post: 9th Nov 2010, 18:03 -
Need advice with PC build for video editing.
By bweath in forum ComputerReplies: 32Last Post: 29th May 2010, 20:04
