Ok so I was trying to backup a DVD to take on a trip with me and I just bought this computer it is a HP Pavilion G6 with a DVDRAM-GT50N DVD drive but when I go to rip the disc the max it rips at is 2.4x I have played with settings in the programs I was using and still the max it will rip is 2.4x. I believe I may be rip locked. Just wondering if anyone knows where I could get the firmware to flash my drive to unlock it.
I have searched for firmware but to no avail. and I have the latest firmware for the DVD drive I was just looking to find a download for the firmware so I can patch it to up its speed.
Results 1 to 15 of 15
Anydvd, clonedvd, dvd decrypter, dvd shrink, img burn, dvdfab and I've played with settings and in imgburn I did the check for firmware updates for the drive but it was unable to locate any for mine.
Try http://www.rpc1.org but be warned that they don't have firmware for everything. There is always a chance that there is no special firmware for your drive. I'm too lazy to check on your drive at that website, so please don't be a lazy sod and make me deeply regret trying to help you by refusing to spend a couple of minutes yourself looking.
about right. it's a slimline drive with both read and write max at 3x.
I found the max read rate like two minutes ago and I have checked the website before and had no luck so no worries i've been to it and browsed. so my next ? would be how hard is it to replace the dvd drive with a better one
the drive is easy enough to remove and replace. the hard part is the faceplate never matches. and the max read/write even on new ones is 8x.
Desktops work
yea i must have jinxed myself moved over to the desktop and now that is taking forever starting to think it just might be the disc have yet to try another one but I'm thinking its the disc causing the issue.
DVDShrink is not recommended for ripping. It hasn't been updated in years and doesn't understand the new bad sector copy protection methods that Sony, Disney and other studios use. It is possible that your DVD is taking a long time because it is using this type of copy protection. "Possible" means "possible" and it does not mean "100% for sure this is your problem".
The only completely reliable rippers any more are DVDFab and AnyDVD. Neither is free, although some non-users here still report that DVDFab is, but they haven't personally installed it in years and seem to not know that DVDFab has stopped putting out free versions of their software. You can try DVDFab before you buy and I think you can also try AnyDVD before you buy. -
also under device manager for my desktop pc I have no IDE Controller section but my drive works to play discs and such. Just something i noticed when I was going to check about DMA
Well I discovered why my desktop was slow with one movie and not others, it was quite simple to simple that I overlooked it. Some of the discs were DL and others were not hence the difference in my ripping speeds. But thanks for all of the advice.
Super Slow rendering in Sony Vegas Pro 11 on brand new machine
By Dojii in forum EditingReplies: 10Last Post: 21st Feb 2013, 20:28 -
Super slow motion video experimentation
By snafubaby in forum Video ConversionReplies: 3Last Post: 27th Mar 2012, 10:45 -
DVD ripping incredibly slow
By moults in forum DVD & Blu-ray WritersReplies: 12Last Post: 18th Jul 2010, 15:31 -
Very slow DVD ripping in Windows 7
By stephens in forum DVD RippingReplies: 16Last Post: 5th Mar 2010, 09:39 -
Super Slow AVS to M2V
By Subblue586 in forum Video ConversionReplies: 4Last Post: 15th Jan 2010, 19:52
