Why not just create a DTS CD? Your unit supports CD (CD-DA, DTS-CD, PC-Files [ISO 9660 file system only]). From what I understand, it takes a special process to embed the DTS track in a DVD so only certain DTS DVDs will play in a DTS certified player where all DTS CDs will play in any modern DVD player since it doesn't use that same special process. I have no idea what that special process is but it's probably an industry secret.
Results 31 to 35 of 35
Perhaps I should have stated the obvious, that I only use LPCM 16/48.
This is a summary of an typical .wav I might input into Apollo:
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
And this is a summary of the .VOB audio Apollo output:
Audio
ID : 189 (0xBD)-160 (0xA0)
Format : PCM
Format settings, Endianness : Big
Muxing mode : DVD-Video
Bit depth : 16 bits
No change there. Guess you're right about Apollo choking on the LPCM 24/96, but I agree with Scott that the authoring support is probably lacking in all but expensive programs. Down sampling may be your only immediate choice if you want to go the DVD route. There is one other thing to consider: if your plan is to create a background image for each track/chapter, keep them simple designs because with LPCM 24/96 and even a moderate sized .jpg you may well exceed 11000 Kb/s which is above the limit of the DVD standard (total: 9848 Kb/s). It may appear to author perfectly well, but not play on your player. It's because of this I wont go higher than LPCM 16/48.
With the rate/depth you want combined with one of my photographs, my total bitrate would exceed 12500 Kb/s. -
Not if you use Still-frame (I-frame-only) MPEGs, then your "video" bitrate is more like 1/20th the bitrate you would normally expect to see.
If you want more info on this, let me know.
Scott -
Hello all,
Let's rewind a bit
Muxman takes the 24/96 files, it made a DVD for me with ALL the files and it was perfect....EXCEPT that all the files were put together in a single track and I want to have separate TRACKS (not chapters, TRACKS)
I did my first DVD with muxman alone, no gui no external program no NOTHING and it came out all right and plays all right but single TRACK...
So the original problem is that i want to split my DVD as "1 song = 1 track" and then I'll make a menu or whatever to access each track individually.
Thanks for the help, I think it's just a muxman setting but I can't find a guide for what I want to do with muxman....
Splitting FLAC audio format.
By greator in forum AudioReplies: 7Last Post: 4th Aug 2016, 08:28 -
Converting 5.1 FLAC and DTS
By sarofski in forum AudioReplies: 19Last Post: 28th Feb 2013, 04:41 -
Converting ALAC to FLAC
By Nitro89 in forum AudioReplies: 4Last Post: 11th Mar 2011, 15:34 -
Converting Flac to MP3
By Alexstarfire in forum AudioReplies: 7Last Post: 28th Jun 2010, 10:59 -
Converting FLAC
By mark91 in forum AudioReplies: 6Last Post: 11th Jun 2010, 17:42
