Results 1 to 9 of 9
    Dec 2010
    quebec
    2 samples , typical + another with a weird visual effect , same specs
    QO.wmv
    Format : Windows Media
    File size : 115 MiB
    Duration : 45mn 51s
    Overall bit rate mode : Constant
    Overall bit rate : 350 Kbps
    Maximum Overall bit rate : 359 Kbps
    Performer : Difav1, Difav1
    Encoded date : UTC 2013-05-22 15:25:40.144
    Application : Windows Movie Maker 2.1.4028.0
    Video
    Format : VC-1
    Format profile : MP@LL
    Codec ID : WMV3
    Codec ID/Info : Windows Media Video 9
    Codec ID/Hint : WMV3
    Description of the codec : Windows Media Video 9
    Duration : 45mn 51s
    Bit rate mode : Constant
    Bit rate : 308 Kbps
    Width : 320 pixels
    Height : 240 pixels
    Display aspect ratio : 4:3
    Frame rate : 30.000 fps
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.134
    Stream size : 101 MiB (88%)
    Language : French (CA)
    tried lots of apps , lots of fails , a few times detected has interlaced (MC) or 15 fps in 30 , figured may be film to wmv ?
    Windows media player plays it good ,
    with some blocks going crazy
    i don't want to fix the shirt effect
    but it may give info on the source
    for a friendly youtube upload
    easy way out ?
    PS . the samples were cut with virualdub
    the mediainfo comes from the source and not the sample
    if it makes any difference ?
  2. I was more pre-occupied with the video/audio sync.
    Dec 2010
    quebec
    i have no audio/video sync issues on my side !?
  4. DECEASED
    Jun 2009
    Heaven
    You will have to re-encode that stuff carefully, since it was generated by the stupid Windows Movie Maker.
    Reasoning: WMM loves Variable Frame Rate, so it loves to drop and duplicate frames.
    Recommendation: use Avisynth w/ DirectShowSource (convertfps=true), or FFMS2 (assuming it can deal with the source file, bien entendu).
  5. Originally Posted by smartel View Post
    When I play your SHIRT clip, the first 0s-28s of audio is out, then it syncs itself (28s-47s) until the end.
    Dec 2010
    quebec
    your right it's a little off
    Dec 2010
    quebec
    http://youtu.be/nG8hooidtmk
    http://youtu.be/Tr6zrVBtP-U
    LoadPlugin("C:\Documents and Settings\Utilisateur\Bureau\VIDEO\MeGUI_2341_x86\t ools\avs\directshowsource.dll")
    DirectShowSource("C:\Documents and Settings\Utilisateur\Bureau\CAMPAGNE ELECTORALE\23\ch20130523_QO.wmv", fps=30.000, audio=true, convertfps=true).AssumeFPS(30,1)
    2 completely different uploads
    Dec 2010
    quebec
    i'm still doing tests on this . FFMS2 gives a much better a/v sync
    but i still have to test some spatial/temporal noise smoother/averager
    any hints ?
