  1. Member KyleMadrid's Avatar
    Feb 2013
    Australia
    Hi all,
    I desperately need to import this h264 ts file into sony vegas but no matter what I try it won't accept it. I've tried muxing it into different containers with tsmuxer and videoredo, and the closest I've gotten to it working is when I put it into an mp4 container but then Sony Vegas tells me I need to download and install quicktime, so I did, and then I try opening it again but it says the same thing... It's really frustrating. I've tried it with many other ts files as well but I always have the same issue.
    Here is the MediaInfo for one of the files I'm trying to import...
    Format : MPEG-TS
    File size : 5.93 GiB
    Duration : 56mn 25s
    Overall bit rate : 15.1 Mbps
    Video
    Menu ID : 3841 (0xF01)
    Format : AVC
    Format version : Version 2
    Format profile : Main@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : 27
    Duration : 56mn 27s
    Bit rate : 13.9 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.269
    Stream size : 5.49 GiB (93%)
    Encryption : Encrypted
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Format settings, Endianness : Big
    Codec ID : 6
    Duration : 56mn 27s
    Bit rate mode : Constant
    Bit rate : 384 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Compression mode : Lossy
    Delay relative to video : 80ms
    Stream size : 155 MiB (3%)
    Language : English
    Jan 2003
    India
    your problem may be due to the fact that both video and audio are encrypted.
  3. Member KyleMadrid's Avatar
    Feb 2013
    Australia
    I thought that might be the case but I've tried it with other ts files that weren't encrypted and they don't import either...
