Hi all my gurus XD
I've a problem never happened before with the avs script creator of megui.
Basically when I try to load the mkv into it with directshowsource as method gives me the following error:
AviSynt script error:
DirectShowSource : Timeout waiting for graph to start.
The file has this properties
And GraphStudio says that is handled by lav video decoder....Code:Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High 10@L5.0 Format settings, CABAC : Yes Format settings, ReFrames : 9 frames Muxing mode : Container profile=Unknown@0.0 Codec ID : V_MPEG4/ISO/AVC Duration : 1h 35mn Bit rate : 13.6 Mbps Width : 1 920 pixels Height : 816 pixels Display aspect ratio : 2.35:1 Frame rate mode : Constant Frame rate : 24.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.361 Stream size : 9.07 GiB (98%) Writing library : x264 core 128 r2216+698 b3c1019 Encoding settings : cabac=1 / ref=9 / deblock=1:-1:-2 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / fade_compensate=0.00 / psy_rd=0.70:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=120 / rc=crf / mbtree=1 / crf=15.0000 / qcomp=0.80 / qpmin=0 / qpmax=81 / qpstep=4 / ip_ratio=1.40 / aq=3:0.90 Default : No Forced : No Color primaries : BT.709 Matrix coefficients : BT.709
I already searched on google for this error but seems that the problem appears only with VC-1 files, and however no of the solutions are actually working....
Any ideas on how to resolve this problem?
ty mates
+Codec ID : V_MPEG4/ISO/AVC
seems like the problem occurs with AVC contentI already searched on google for this error but seems that the problem appears only with VC-1 files,...
-> Have you tried using FFmpegSource2 instead of DirectShowSource as source filter? -
atm DirectShowSource as file index, instead of DirectShowSource one should be able to select FFmpegSource2.
Add QTGMC Deinterlacer to MeGUI's avisynth script creator drop down list?
By Simcut in forum Newbie / General discussionsReplies: 2Last Post: 30th Jul 2012, 16:58 -
Certain d2v file causing problems with MeGUI Avisynth Script Creator.
By Simcut in forum Newbie / General discussionsReplies: 5Last Post: 30th Jul 2012, 16:57 -
meGUI + AVS - cannot obtain audio
By PsyCLown in forum AudioReplies: 1Last Post: 19th Jan 2011, 05:20 -
a problem with megui script
By kronick in forum DVD RippingReplies: 6Last Post: 25th Sep 2009, 13:42 -
How do I create an AVS script
By Sopt Finder in forum Newbie / General discussionsReplies: 4Last Post: 15th Jun 2009, 13:17
