Is there a way to join multiple MP3 files, for example a live recording split into multiple files, that will give seamless transitions
Results 1 to 9 of 9
Got that. tried it. does everything needed. One further question. When joining say a live show split into clips, is there a way to fine tune the join to get it truly seamless.
I used Audacity to join an album that had 10 clips. I got the joins pretty good after messing around. Just wondered if there was a simpler way to fine tune the joins. -
Click the plus icon and zoom in on the point where the tracks are joined, then you can add a second or so of silence you copy and paste from another area to make it play nice. You can also highlight and delete a bit to sync up the sounds or use the fade in/fade out effects depending on how you like it to play. That usually works for me when I'm fine tuning a mix anyway.
Old home videos are historical documents that may be best used to annoy your children. -
mp3DirectCut. You can open multiple instances of mp3DirectCut, each opening a different MP3, and copy and paste between them etc. I've used it to join MP3 files that way many times, and the process is lossless.
Seemless transitions may be another story..... it depends on the MP3 files in question, but mp3DirectCut can do fade ins and outs etc as well as basic editing etc.
How to join/merge MP4's (H264) with AVIdemux
By czgirb in forum LinuxReplies: 5Last Post: 20th Sep 2012, 09:38 -
How to join (merge) HD m2ts files?
By slobadaca in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 1st Feb 2011, 13:58 -
Join/Merge several mp3 into a new one
By elmuz in forum AudioReplies: 0Last Post: 21st Jul 2010, 04:02 -
Question about using Audacity to join mp3 files
By jimdagys in forum AudioReplies: 2Last Post: 25th Dec 2008, 07:21 -
merge / join 2 MPG2 files
By joelore in forum Newbie / General discussionsReplies: 4Last Post: 21st Jun 2008, 22:14
