I couldn't find a tool to do this when I went into the search function. I looked for VOB2 and then under DVD. So also hoping I'm posting to the right forum.
I ripped a DVD last night. It has about 10 menus that have 1 to 4 images in each. Instead of doing this manually, was hoping of a freeware method to just batch convert all the menu VOBs into their constituent images (preferably in PNG output format rather than BMP or JPG images. BMP too large, JPGs to lossy, often).
Is there anything that can do that, anyone know?
The ideal would be to just batch the following, say:
VTS_08_1.VOB
VTS_01_1.VOB
VTS_02_1.VOB
VTS_03_1.VOB
VTS_04_1.VOB
VTS_05_1.VOB
VTS_06_1.VOB
VTS_07_1.VOB
so that as an example, VTS_08_1.VOB would produce output something like:
for the 4 images it contains.
Thanks for any help re this.
Cheers.
I don't know if you can do it in batch mode (ie, automated from the command line) but VirtualDub with the MPEG source plugin can import a VOB then export as a numbered series of PNG images (with whatever base name you want). You can limit the range if you want using the mark-in, mark-out tools.
ffmpeg could also be used to do the deed when called in a batch,.. see: http://www.catswhocode.com/blog/19-ffmpeg-commands-for-all-needs
Extract frame from VOB file.
By kwazi in forum ProgrammingReplies: 8Last Post: 17th May 2013, 17:24 -
How to extract mpeg2 from VOB without reencoding?
By rh_1363 in forum DVD RippingReplies: 9Last Post: 4th Apr 2012, 14:05 -
How to extract audio from .vob files
By webadm in forum Newbie / General discussionsReplies: 4Last Post: 16th Jan 2012, 21:28 -
Trying to extract VOB file with Isobuster, nothing happens?
By dai3504 in forum DVD RippingReplies: 2Last Post: 8th May 2011, 10:42 -
extract subtitles from .VOB file
By avextraxjp in forum Newbie / General discussionsReplies: 2Last Post: 10th May 2010, 12:19
