Hy there,
Could someone guide me how to convert some subtitles into xml format? I need to use xml format for Captions for a web flash player.
My subtitles are in .ass format and i can't find any solution to convert them to .xml to be comptatible with the video player.
I have tried a lot of solutions to convert them to xml format but the subtitles won't show on the player.
Results 1 to 17 of 17
Solution is simple: Write your own code... Or read direct subtitle file.
i don't know anything about xml.. how to write my own code..
can't read the direct subtitle.. only .xml files work -
yes that is fine and tandy, but how i am going to edit xml file for a 1000 rows subtitle ? and i need to do this every week.
it will take a lot of time.
i will need to edit the duration of the subtitle, timestamps and so on... -
I'm not quite sure if this is what you're seeking but Subtitle Edit allows you to export your subtitles to BDN xml/png format
lol.. it exports only to png not xml..
it appeared over 255 pictures on my desktop
In Subtitle Edit you can save a subtitle in 150+ formats including many different xml formats - which xml format do you need exactly for your web flash player? "Timed Text" is a good guess...
hmm tried few so far none will show.. i have no idea what kind of xml i need.. it just says xml file for subtitles.
Hm, xml files can be anything... I don't suppose you got a sample file that works?
And I'm still rather clueless.
But perhaps you could simply hardcode the subtitles? -
yes.. i know that.. done that.. but don't what to waste time hardcodding the subs.. but i figured it out.. xml works now
and thankfully he shared the solution with everybody else.I knew my answer would help you!
And he has to do this every week
This thread just puts me in a good mood.Last edited by videobruger; 22nd May 2013 at 14:27.
Subtitles get embeded in WMV when converting from MKV using Format Factory
By PlayWithFire in forum Video ConversionReplies: 10Last Post: 12th Jul 2012, 10:22 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 20:00 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
Converting DVDs to playable PS3 format with hardcoded or external subtitles
By oldjoe911 in forum User guidesReplies: 0Last Post: 10th Sep 2008, 12:52 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 08:21
