Whenever I try to play the ISO it looks like it works, but then immediately exits.
Do I have to update my MEncoder/MPlayer in some form?
Please post the exact message(s) that Mplayer displays before exiting.
Example:
Code:=>Mplayer -vc ffvc1 -cache 8192 Sintel.m2ts MPlayer Redxii-SVN-r36207-4.6.3 (C) 2000-2013 MPlayer Team Custom build by Redxii, http://smplayer.sourceforge.net Compiled against FFmpeg version N-52649-g6021615 Build date: Thu May 2 00:16:57 EDT 2013 181 audio & 389 video codecs Playing Sintel.m2ts. Cache fill: 0.00% (0 bytes) libavformat version 55.4.100 (internal) TS file format detected. VIDEO VC1(pid=4113) AUDIO DTS(pid=4352) NO SUBS (yet)! PROGRAM N. 1 Searching for VC1 sequence header... found VIDEO: VC-1 960x408, 24.000 fps, header len: 24 Load subtitles in ./ ========================================================================== Forced video codec: ffvc1 Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family libavcodec version 55.6.100 (internal) Movie-Aspect is undefined - no prescaling applied. VO: [directx] 960x408 => 960x408 Planar YV12 Selected video codec: [ffvc1] vfm: ffmpeg (FFmpeg WVC1) ========================================================================== ========================================================================== Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders AUDIO: 48000 Hz, 2 ch, floatle, 384.0 kbit/12.50% (ratio: 48000->384000) Selected audio codec: [ffdca] afm: ffmpeg (FFmpeg DTS) ========================================================================== AO: [dsound] 48000Hz 2ch s16le (2 bytes per sample) Starting playback... Movie-Aspect is 2.35:1 - prescaling to correct movie aspect. VO: [directx] 960x408 => 960x408 Planar YV12
He's right. Need the log file.
Are you actually using mplayer from the command line or using a front end for it? The reason I'm asking is that if you're using it in command line mode I'd think you'd already have figured out searching "mplayer play iso" and "mplayer log file". Most mplayer front ends like smplayer will have the option to save/display mplayer crash logs.
iso playback has been supported in mplayer for at least 5 years. You shouldn't need an update.
Playing Blue-ray ISO?
By Espo99 in forum Blu-ray RippingReplies: 1Last Post: 1st Jan 2012, 12:39 -
Playing ISO images via BlueRay
By werdna99 in forum Video Streaming DownloadingReplies: 1Last Post: 23rd Dec 2011, 16:39 -
help wanted playing FLV in mplayer
By dunce in forum Software PlayingReplies: 9Last Post: 13th Sep 2010, 09:01 -
Playing an iso file
By ronens in forum Newbie / General discussionsReplies: 2Last Post: 5th Jan 2009, 10:01 -
playing an iso file
By ronens in forum Newbie / General discussionsReplies: 0Last Post: 4th Jan 2009, 21:29
