I need to create a DVD for a project at work
Needs to have a main menu with 4 selections
under each selection there will be about 20 short videos (under 1 min) you can select to watch. When the short clip is done it needs to take you back to the submenu you were just at. All of the videos are in .mov but I will convert them (suggestions?).
I have both PC and MACs to use. I will buy any software needed, not looking just for free.
If someone can help me pick a software that will do this, that would be great! Thank you
dvd styler(free) or tmpgenc authoring works(not free but easier to use).
thank you.
as it turns out we had tmpgenc auth 4 from when a previous person did the dvd a couple of years back.
Looks like what I need it to do is:
Top menu, 4 tracks.
in each of those 4 tracks, the clips will be chapters. about 20-30 in each track.
My only problem is I need it to go back to the track menu after each chapter is played.
IE: If I play the 30 second clip (chapter 7) as soon as it ends, take me back to the track menu that has those chapters listed.
Is there any way I can do this?
Thank you! -
looks like im going to need pgcedit to do this.
Anyone that can help me with this? I've got the basic DVD structure made using tmpgenc auth 4.
I have a top menu and 4 tracks
in each track are my acutal videos (chapters). I can select one and it plays from there until the end. I need it to play one and go back to the menu (the track menu, not the main top menu). I would also like it to go to the menu I was just on.
IE: I'm on track 2, page 3 and select a video. When its done playing, go back to track 2 page 3 menu.
Sorry I dont know what those are really called. Thanks in advance for any help.
Trying to pick out a new graphics card
By CorrTerek in forum ComputerReplies: 14Last Post: 19th Jul 2010, 02:28 -
Ripbot how to pick the right file?
By David9799 in forum Blu-ray RippingReplies: 4Last Post: 3rd Jan 2010, 15:59 -
trying to pick the best dvd software player for my "old" laptops
By cubajean10 in forum Newbie / General discussionsReplies: 1Last Post: 5th Dec 2009, 19:01 -
what does this reciever pick up? (UK)
By snadge in forum DVB / IPTVReplies: 0Last Post: 27th Feb 2009, 17:52 -
can't pick up 1 channel on 1 TV
By pos1 in forum DVB / IPTVReplies: 9Last Post: 24th Feb 2009, 14:23
