  1. is there a similar program to the above as I have now reinstalled CXTDVD 4 times and when I try and add avi movie clips it just freezes up and says not responding I have used this program for ages now and can't make it out.
    Upgrade to convertxtodvd 5?
    Or try avstodvd.
  3. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Maybe there is a video or audio codec inside that particular avi "container" that the program does not accept?
  4. Originally Posted by Baldrick View Post
    Or try avstodvd.
    I have upgraded to version 5 but will try avitodvd see if that is ok
    hech54
    Re: convertxtodvd prpblem
    yes maybe there is will also check this too
    many thanks all for your help
