I looked at your profile and you're running linux mint. Avidemux 2.6 isn't in the ubuntu repos, and most mint is ubuntu or debian based, so it probably isn't in the mint ones either. I use ubuntu (though I've had mint installed before) and I'm pretty conservative about software sources so I use 2.5.whatever.
You could install 2.6 in mint but you'd have to add their ppa and build it. I haven't done this myself. I'd rather wait until it's in the repos and there are other good linux editors/converters like kdenlive, openshot, and pitivi for a start. Actually I think the selection is better in linux. In fact I've used openshot to convert files everything else choked on.
As mentioned, you need to know what codec you're talking about. Is it just one file? Mp4 isn't a codec, it's a wrapper. It can contain a number of codecs. If it's mpeg4 visual or something like that it's easier to find software to edit. H.264 is harder. -
There is more than one type of mpeg4 video. That didn't help, I'm afraid.
But it's a number of files? I've used avidemux often in ubuntu. it rarely chokes on any mpeg-4 type, just examples made with flaky codec versions.
You need to do as baldrick suggests and post mediainfo text output. If you don't have it get it. It's in the ubuntu repos and therefore also for mint.
avidemux problem
By tysn in forum Newbie / General discussionsReplies: 0Last Post: 24th Sep 2012, 01:45 -
Avidemux aspect ratio question [from newbie to Avidemux]
By ANOther1676 in forum EditingReplies: 1Last Post: 20th Jan 2012, 20:07 -
Problem with Avidemux 2.5
By MohamedYousri in forum Newbie / General discussionsReplies: 13Last Post: 3rd Jan 2011, 16:37 -
Avidemux Problem.
By tremor209 in forum Newbie / General discussionsReplies: 2Last Post: 11th Nov 2010, 04:39 -
Avidemux Problem...
By userpc in forum EditingReplies: 0Last Post: 6th Oct 2010, 08:52
