I have a burned cd with cda files on it, both pc's can play the 1st track,thats it.
I have tried to rip the cda files with many programs to various formats and in the end it only will allows me to play
3 of the 16 tracks the other ones are silent (i use vlc) but I tried the cd in the car and it plays all 16 easy, same with a
portible dvd player i tried it on.
what is the problem?
Results 1 to 10 of 10
You better use EAC if you're having playback problems on a PC but not elsewhere. This really should not be the case since you say it's a burned disc, but this sounds suspiciously to me like how some of the CD anti-copy technology has worked in the past. Interestingly this stuff was rarely used in the USA, but Europe and Asia used it quite a bit for a while. Basically it did some stuff to deliberately screw up the CD kind of like how bad sector copy protection works in DVDs. PCs had massive problems playing the discs unless a special player, usually on the CD itself, was used, but any standalone device capable of playing CD audio discs (ie. car players, CD players, DVD players) could play them without any problems. The anti-copy technology exploited a difference in the way PCs handle discs over standalone players. EAC knows how to handle this kind of thing so I strongly recommend you use it.
It is a great program and very versatile.
I am kind of surprised that it has not been updated in so long, but then maybe it does not need to be yet.
It is also amazing that it is a free program as I would gladly pay for it!! -
than donate a few bugs (donation link is on their homepage)It is also amazing that it is a free program as I would gladly pay for it!!
AnonymousGuest
@Selur
I hope you mean bucks because the program doesn't need anymore bugs....ha ha
It's a excellent program that doesn't seem to be ever out of beta, but it works very well. -
All CD's and DVD's show up as an audio disc with track00.cda
By drew_2 in forum Software PlayingReplies: 3Last Post: 6th Sep 2010, 17:37 -
Query: Best way to go from a cda. file to plain PCM is ??????
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 6Last Post: 22nd Jun 2010, 21:46 -
Can't play audio CDs (.cda)
By kapow85 in forum ComputerReplies: 8Last Post: 1st Oct 2008, 04:47
