hey guys i am new i was reading online disk at once error then i came across this site and i like it please need help
i am burning dual layer dvd but got error
if any one can help will be very thanks ful
and i try imgburn with same imag file and same dvd-r dl
got this error i uploaded the picture
new lg bd bruner still same error and had tryed dvd+r dl and dvd-r dl
********** Nero Multimedia Suite 10 | Nero Recode **********
Version: 4.10.4.100
Project type: Remake a DVD
Compilation name: My Disc
Target size: DVD9 (4152290)
20:32:16 File LangStreamPatcher.cpp, Line 61
Command table patching started...
20:32:16 File LangStreamPatcher.cpp, Line 144
All tables successfully patched!
Burn settings:
Target: HL-DT-ST BD-RE BH14NS40
Number of copies: 1
Write speed: 0 KB/s
Temp folder: C:\Users\Vipun\Documents\Nero Recode\VIDEO_TS (79141736448 bytes free)
Direct burning: false
Target media: DVD DL
Shutdown when finished: false
Advanced Analysis: true
Compress Adaptive: false
20:32:39 File burn_dvdfiles.cpp, Line 241
Compile DVD: init
VTS_01 Title Vobs [10400 vobus] 4028.16MB -> 4028.15MB [R 1.00]
Video: 3847.77MB, extra: 180.38MB
Audio: 1 streams
0. 0. Dolby Digital 2-ch Unspecified 160.06MB [enabled]
Subpicture: 0 streams
VTS_02 Title Vobs [9094 vobus] 3695.16MB -> 3695.14MB [R 1.00]
Video: 3537.03MB, extra: 158.11MB
Audio: 1 streams
0. 0. Dolby Digital 2-ch Unspecified 140.35MB [enabled]
20:32:39 File burn_dvdfiles.cpp, Line 1295
Compile DVD: begin copy 1
20:32:39 File burn_dvdfiles.cpp, Line 810
Compile DVD: begin deep analysis
20:43:48 File burn_dvdfiles.cpp, Line 567
Compile DVD: burning 4152290 sectors (3954433 required)
20:43:48 File burn_dvdfiles.cpp, Line 781
Compile DVD: adjust target size to 8109.94MB (7723.50MB obtained)
20:43:48 File burn_dvdfiles.cpp, Line 615
Compiling DVD Volume started
20:46:10 File NeroRecorder.cpp, Line 664
Added extra file VTS_01_2.VOB
20:47:43 File NeroRecorder.cpp, Line 664
Added extra file VTS_01_3.VOB
20:49:02 File NeroRecorder.cpp, Line 664
Added extra file VTS_01_4.VOB
20:50:00 File burn_dvdfiles.cpp, Line 1201
Compile DVD: finished VTS_01 Title Vobs
VTS_01 Title Vobs:
Original 4028.16MB -> Expected 4028.15MB -> Output 4028.15MB
Finished error 0.00MB
Ratio encoded = 0
Original encoded = 10400
Slide encoded = 0
StillImage encoded = 0
Output extra size = 181.67MB
Source video size = 3846.48MB
Pictures Modified [I 0] [P 0] [B 0]
20:51:49 File NeroRecorder.cpp, Line 664
Added extra file VTS_02_2.VOB
20:52:59 File NeroRecorder.cpp, Line 664
Added extra file VTS_02_3.VOB
20:53:58 File NeroRecorder.cpp, Line 664
Added extra file VTS_02_4.VOB
20:54:25 File burn_dvdfiles.cpp, Line 1201
Compile DVD: finished VTS_02 Title Vobs
VTS_02 Title Vobs:
Original 3695.16MB -> Expected 3695.14MB -> Output 3695.14MB
Ratio encoded = 0
Original encoded = 9094
Slide encoded = 0
Output extra size = 158.86MB
Source video size = 3536.28MB
20:54:27 File burn_dvdfiles.cpp, Line 639
Compile DVD: completed successfuly (7723.50MB)
20:54:29 File NeroRecorderBase.cpp, Line 1424
Burning 14 files with total size of 8098678784 bytes on hard disk
20:54:29 File burn_dvdfiles.cpp, Line 1295
21:16:49 File NeroRecorderBase.cpp, Line 522
Writing to disc: DVD+R DL
Windows 7 6.1
AMD64
Wow64Process
Nero API version: 10.6.0.100
Using interface version: 10.1.0.0
Installed in: C:\Program Files (x86)\Nero\Nero 10\Nero Recode\NeroAPIFiles\
Application: Nero\Nero Recode
Internal Version: 10,6,0,100
Recorder: <HL-DT-ST BD-RE BH14NS40>Version: 1.01 - HA 1 TA 1 - 10.6.0.100
Adapter driver: <Serial ATA> HA 1
Drive buffer : 4064kB
Bus Type : via Inquiry data
=== Scsi-Device-Map ===
=== CDRom-Device-Map ===
TSSTcorp CDDVDW SH-S223L F: CdRom0
HL-DT-ST BD-RE BH14NS40 G: CdRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 4095MB (4193400kB)
Free physical memory: 2475MB (2535312kB)
Memory in use : 39 %
Uncached PFiles: 0x0
Global Bus Type: default (0)
Check supported media : Disabled (0)
19.5.2013
NeroAPI
21:16:49 #1 PHASE 112 File APIProgress.cpp, Line 275
DVD-Video files reallocation started
21:16:49 #2 PHASE 114 File APIProgress.cpp, Line 275
DVD-Video files reallocation completed (no file modified)
21:16:49 #3 PHASE 111 File APIProgress.cpp, Line 275
DVD-Video files sorted
21:16:49 #4 Text 0 File SCSIPTICommands.cpp, Line 464
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
21:16:49 #5 ISO9660GEN -11 File Geniso.cpp, Line 3336
First writeable address = 0 (0x00000000)
21:16:49 #6 PHASE 1 File APIProgress.cpp, Line 259
21:16:49 #7 PHASE 2 File APIProgress.cpp, Line 259
Creating directories
21:16:49 #8 Text 0 File UDFCreator.cpp, Line 1057
Start of DVD Video file sequence with 2 title sets.
VIDEO_TS.IFO size=(3:0): pad=0 -> start=0
VIDEO_TS.BUP size=(3:0): pad=0 -> start=3
VTS_01_0.IFO size=(28:0): pad=0 -> start=6
VTS_01_1.VOB size=(524287:0): pad=0 -> start=34
VTS_01_2.VOB size=(524287:0): pad=0 -> start=524321
VTS_01_3.VOB size=(524287:0): pad=0 -> start=1048608
VTS_01_4.VOB size=(489550:0): pad=0 -> start=1572895
VTS_01_0.BUP size=(28:0): pad=0 -> start=2062445
VTS_02_0.IFO size=(24:0): pad=0 -> start=2062473
VTS_02_1.VOB size=(524287:0): pad=0 -> start=2062497
VTS_02_2.VOB size=(524287:0): pad=0 -> start=2586784
VTS_02_3.VOB size=(524287:0): pad=0 -> start=3111071
VTS_02_4.VOB size=(319051:0): pad=0 -> start=3635358
VTS_02_0.BUP size=(24:0): pad=0 -> start=3954409
End of DVD Video file sequence.
21:16:49 #9 Text 0 File DVDPlusDualLayer.cpp, Line 1462
SetDriveCaps: Set LAST LBA of layer 1 to 2062783
21:16:49 #10 Text 0 File compose.cpp, Line 935
GenUDF2: 1 transfer items prepared.
21:16:49 #11 PHASE 6 File APIProgress.cpp, Line 259
Finishing
21:16:49 #12 ISO9660GEN -11 File Geniso.cpp, Line 3336
21:16:49 #13 PHASE 1 File APIProgress.cpp, Line 259
21:16:49 #14 PHASE 2 File APIProgress.cpp, Line 259
21:16:49 #15 Text 0 File Burncd.cpp, Line 3521
Turn on Disc-At-Once, using DVD media
21:16:49 #16 PHASE 74 File APIProgress.cpp, Line 259
Checking discs
21:16:49 #17 Text 0 File DlgWaitCD.cpp, Line 314
[G: BD-RE BH14NS40 ] Last possible write address on media: 4173823
Last address to be written: 3954991
21:16:49 #18 Text 0 File DlgWaitCD.cpp, Line 326
[G: BD-RE BH14NS40 ] Write in overburning mode: NO (enabled: CD)
21:16:49 #19 Text 0 File DlgWaitCD.cpp, Line 2917
Recorder: HL-DT-ST BD-RE BH14NS40, Media type: DVD+R DL
Disc Manufacturer ID: <RITEK>, Media Type ID: <S04>, Product revision number: 66
Disc Application Code: 0, Extended Information Indicators: 3
21:16:49 #20 Text 0 File DlgWaitCD.cpp, Line 499
[G: BD-RE BH14NS40 ] >>> Protocol of DlgWaitCD activities: <<<
21:16:49 #21 Text 0 File ThreadedTransferInterface.cpp, Line 861
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 3954992 (3954992) = #3954992/878:53.17
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 3954992 blocks [G: HL-DT-ST BD-RE BH14NS40]
21:16:49 #22 Text 0 File ThreadedTransferInterface.cpp, Line 1077
Prepare [G: HL-DT-ST BD-RE BH14NS40] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 8099823616, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 3954992 | 0 | 0x00
3954992 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
MediaType: DVD+R DL
21:16:54 #23 Text 0 File SCSIPTICommands.cpp, Line 251
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
21:16:54 #24 Text 0 File Burncd.cpp, Line 4234
Caching options: cache CDRom or Network-No, small files-Yes (<32KB)
21:16:54 #25 PHASE 24 File APIProgress.cpp, Line 275
Caching of files started
21:16:54 #26 Text 0 File Burncd.cpp, Line 4356
Cache writing successful.
21:16:54 #27 PHASE 25 File APIProgress.cpp, Line 275
Caching of files completed
21:16:54 #28 PHASE 36 File APIProgress.cpp, Line 275
Burn process started at 8x (11,080 KB/s)
21:16:54 #29 Text 0 File ThreadedTransferInterface.cpp, Line 2850
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
21:16:54 #30 SPTI -1066 File SCSIPassThrough.cpp, Line 224
CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1066)
CDB Data: 0xAC 00 00 00 00 00 00 00 00 64 00 00
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 24
Buffer x0cd2ffc0: Len x648
21:16:54 #31 Text 0 File DVDPlusDualLayer.cpp, Line 1943
GetDriveCaps: LAST LBA of layer 1 is 2062783
21:16:54 #32 SPTI -1066 File SCSIPassThrough.cpp, Line 224
CDB Data: 0xAD 00 00 00 00 00 00 21 08 04 00 00
Sense Code: 0x24
Sense Qual: 0x00
Buffer x0cf97c00: Len x804
21:16:54 #33 Text 0 File DVDPlusDualLayer.cpp, Line 1462
21:16:54 #34 Text 0 File DVDPlusDualLayer.cpp, Line 1943
21:16:54 #35 Text 0 File DVDPlusDualLayer.cpp, Line 787
L0 Data Zone Capacity set to 2062784 (1F79C0h, 4028MB) -> OK, confirmed setting
21:16:54 #36 CDR -1205 File DVDPlusDualLayer.cpp, Line 814
Burning Layer 1
21:16:54 #37 Text 0 File DVDPlusDualLayer.cpp, Line 824
Start writing layer 1 at address 0 (0h)
Recording mode: unknown Recording Mode
21:16:54 #38 Text 0 File Cdrdrv.cpp, Line 10508
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R DL (14), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Transfer Rate: <not specified> (F h)
Number of Layers: 2, Track Path: Opposite Track Path (OTP), Layer Type: recordable
Linear Density: 0,293 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: FCFFFF h
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 3 h
Disc Manufacturer ID: RITEK...
Media type ID: S04
Number of Physical format information bytes in use in ADIP up to byte 63: 64
Media Specific [16..783]:
00 00 03 52 49 54 45 4B - 00 00 00 53 30 34 42 40 ...RITEK...S04B@
25 25 37 15 00 34 6E 00 - 34 6E 1A 1A 0C 0C 0E 0E %%7..4n.4n......
00 00 00 10 00 1A 1A 0C - 0C 0E 0E 00 00 00 10 00 ................
04 00 33 7B 5C 00 33 66 - 40 19 10 05 04 10 00 00 ..3{\.3f@.......
00 00 00 55 6A 32 24 16 - 09 08 20 00 00 00 00 05 ...Uj2$.........
84 00 00 48 6E 28 24 16 - 09 08 20 00 00 00 00 00 ...Hn($.........
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
E1 0F 32 10 00 03 00 00 - 00 FC FF FF 00 22 D7 FF ..2.........."..
21:16:54 #39 SPTI -1066 File SCSIPassThrough.cpp, Line 224
CDB Data: 0xFC 00 2B 52 54 42 00 00 04 00 00 00
Sense Code: 0x24
Sense Qual: 0x00
Buffer x099f7400: Len x4
0x00 00 00 00
21:16:54 #40 Text 0 File DVDR.cpp, Line 5631
Drive: HL-DT-ST BD-RE BH14NS40
Book Type request [LG]: DVD-ROM
Changing the Book Type was finished with error, return code -1066
21:16:54 #41 SPTI -1066 File SCSIPassThrough.cpp, Line 224
Sense Code: 0x24
Sense Qual: 0x00
Buffer x0cfb0180: Len x648
21:16:54 #42 Text 0 File DVDPlusRW.cpp, Line 637
Start write address at LBA 0
DVD high compatibility mode: Yes
21:16:54 #43 Text 0 File ThreadedTransfer.cpp, Line 273
Pipe memory size 83836800
21:16:54 #44 PHASE 42 File APIProgress.cpp, Line 259
Writing lead-in
21:16:54 #45 Text 0 File CUDFTransferItem2.cpp, Line 712
GenUDF2 FS Layout:
Sectors to be written: 3954992
Session Start: Sector 0
Volume Structure: Sector [0, 261] (262 Sectors)
Meta Data: Sector [262, 283] (22 Sectors)
Data: Sector [284, 3954719] (3954436 Sectors)
Trailer Track: Sector [3954720, 3954991] (272 Sectors)
GenUDF2 Parameters:
PrepTime: 05-19-2013 21:16:49
UDF Revision: 1.02
UDF Partition Type: Physical
UDF Special Mode: DVDVideo
Bytes per Sector: 2048
Session Start: 0
Physical Partition Start: -1
Total Capacity: 4173824
Multi Session Mode: Continue
Disc Type: DVD+R DL
OS Class: 0
Volume ID: My Disc
Allow Unicode Labels: 0
Duplicate Meta Data: 1
MS Info File: 00000000
VMS Rollback File: 00000000
Create ISO bridge: 1
ECC Block Length: 16
Sparing Packet Length: 32
Allocation Unit Size: 32
Alignment Unit Size: 16
Make Writable: 0
Access Type: Read-only
21:17:42 #46 PHASE 77 File APIProgress.cpp, Line 259
Writing tracks
21:29:05 #47 SPTI -1135 File SCSIPassThrough.cpp, Line 224
CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1135)
CDB Data: 0x2A 00 00 1B D9 20 00 00 20 00 00 00
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
Sense Area: 0x71 00 03 00 00 00 00 0A 00 00 00 00 0C
Buffer x1b08c880: Len x10000
0x00 00 01 BA 45 8B E4 E9 3C AD 01 89 C3 F8 00 00
0x01 E0 07 EC 81 00 00 A2 46 BE E4 EC C4 6C 86 70
0x3E A6 03 BC 9D 01 85 72 58 48 19 02 C8 C1 48 42
21:29:05 #48 TRANSFER -20 File ThreadedTransfer.cpp, Line 1222
Could not perform Write
21:29:05 #49 CDR -1135 File Writer.cpp, Line 335
Write error
21:40:41 #50 SPTI -1176 File SCSIPassThrough.cpp, Line 224
CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1176)
CDB Data: 0x51 00 00 00 00 00 00 00 20 00 00 00
Sense Code: 0x72
Sense Qual: 0x02
Sense Area: 0x71 00 03 00 00 00 00 0A 00 00 00 00 72 02
Buffer x0cfaf980: Len x20
21:40:41 #51 Text 0 File DVDPlusRW.cpp, Line 901
EndDAO: Last written address 1825056
21:40:41 #52 CDR -1176 File WriterStatus.cpp, Line 291
Session fixation error
21:40:41 #53 TRANSFER -24 File ThreadedTransfer.cpp, Line 1222
Could not perform end of Disc-at-once
21:40:41 #54 Text 0 File DVDPlusDualLayer.cpp, Line 1462
SetDriveCaps: Set LAST LBA of layer 1 to 0
21:40:41 #55 PHASE 38 File APIProgress.cpp, Line 275
Burn process failed at 8x (11,080 KB/s)
21:40:41 #56 Text 0 File SCSIPTICommands.cpp, Line 301
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
21:40:41 #57 Text 0 File Cdrdrv.cpp, Line 11878
DriveLocker: UnLockVolume completed
21:40:41 #58 Text 0 File SCSIPTICommands.cpp, Line 464
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
21:40:48 #59 PHASE 6 File APIProgress.cpp, Line 259
Finishing
21:40:48 File NeroRecorderBase.cpp, Line 1228
Burn failed (3)
21:40:48 File burn_dvdfiles.cpp, Line 314
Compile DVD: exit
I have never tried using ImgBurn to burn an ISO made by another program, but as I recall from discussions here at VideoHelp, if you try to burn an ISO to a dual layer DVD with Imgburn and you don't have the .mds file, ImgBurn won't be able to set the layer break.
If you don't have the .mds, then you will need to use the original files and folders (VIDEO_TS and AUDIO_TS folders and their contents) instead of an ISO to be able to set the layer break. If you do not have the original files and folders, I think CD-Roller or ISOBuster can extract them from an ISO. -
Your DL disc is also low quality garbage. Even if you get the main issues resolved, don't be surprised if your burn fails or the disc becomes unreadable in a few years.
The ONLY DVD+R DL discs you should ever buy are those made by Verbatim. Everything else is what one guy here described as "landfill grade media". -
Check out the review for the LG BH14NS40 at CDRLabs. If you scroll down to the DVD-DL test, you get to see the difference between a burn with Verbatim and those RITEK S04B.
Have you tried playing the disc, it looks like the burn finished, but Nero could not write the lead out. That's definitely a sign of poor quality media.
You could try a firmware update. -
guys which dvds should i buy dvd-r or dvd+r dual layer is ebay trust ful to buy those dvds
thanks
About DVD Dual layer burning more then said capacity
By vikas.babu in forum Authoring (DVD)Replies: 2Last Post: 31st Dec 2012, 03:43 -
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 04:16 -
Burning AVCHD File To Dual Layer DVD
By Falco21 in forum Authoring (Blu-ray)Replies: 4Last Post: 15th Mar 2011, 12:16 -
Dual-Layer burning of DVD using nero?
By mr_jbloggs in forum Newbie / General discussionsReplies: 3Last Post: 25th Sep 2008, 08:26 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 10:00
