Hi all....
I am using win xp and when i try to combine 2 to 3 .AVI files to create a DVD...the subtitles are missing. but they are there in the actual movie (when play it on my computer) , i can see the subtitles and read it. but after combining the 2-3 .AVI files and creating a menu etc...the final output of DVD does not show subtitles ? has it got anything to do with Divx or something ? pls advise.
Probably a .divx/.avi created with for example AVIAddXSubs . Nope I don't know anything that can hardcode or extract the subs from it.
It is apparently possible to demux them if they are muxed into an AVI container, but it's probably way beyond anything a new member can do. But if you feel adventurous, here you go.
https://forum.videohelp.com/threads/294095-Extract-subtitles-from-avi
Convert .Ts files with subtitles hardcoded in the output file
By vjerioni in forum Video ConversionReplies: 10Last Post: 10th Apr 2014, 13:37 -
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 09:58 -
Converting AVI to DVD using DVD Flick: low quality result
By e2p in forum Video ConversionReplies: 13Last Post: 28th Oct 2010, 11:50 -
DVD Flick- audio out of sync and subtitles wont show
By gogumakilla in forum Authoring (DVD)Replies: 2Last Post: 4th Nov 2009, 04:09 -
DVD FLick Audio Encoding Error on AVI videos produced by Canon camera
By patplh in forum Authoring (DVD)Replies: 18Last Post: 14th May 2009, 19:58
