I'm getting a message, that it cannot resample 6 channels into 2 channel audio. This is the command i'm using to convert into h.264+aac:
avconv -i /var/movies/Some.movie.2010.BDRip.XviD.AC3.-HQ-ViDEO.avi -strict experimental -acodec aac -ac 2 -ab 128k -ar 44100 -y -c:v libx264 -qscale 1 -s 640x480 -g 25 -r 25 /path/to
Exact message:
Resampling output channel count must be 1 or 2 for mono input; 1, 2 or 6 for stereo input; or N for N channel input.
Can not resample 6 channels @ 48000 Hz to 2 channels @ 44100 Hz
I have tried so many configurations, have tired experimenting.
Any video guru out there? Some tip would be awesome.
Thanks.
I'm using:
avconv version 0.8.6-4:0.8.6-0ubuntu0.12.04.1, Copyright (c) 2000-2013 the Libav developers
built on Apr 2 2013 17:02:36 with gcc 4.6.3
-> http://www.ffmpeg.org/ffmpeg-filters.html#Mixing-examples should be able to do the job,...
(personally I use sox for downmixing -> http://forum.doom9.org/showthread.php?t=152034 and from the looks of it one can probably 'translate' the sox calls I use into ffmpeg calls) -
Did you use the code from the example or did you adjust it to another downmix?
Demultiplexing of 4 video channels and 2 audio channels.
By jays_jays30 in forum Video ConversionReplies: 1Last Post: 9th Jul 2012, 10:29 -
trying to extract the 7.1 channels (8 channels) from Blu-ray disc
By billsantos in forum AudioReplies: 2Last Post: 20th Feb 2011, 16:28 -
How to resample the audio of a WMV file ?
By turbo20010 in forum AudioReplies: 22Last Post: 13th Jan 2011, 13:21 -
let the standalone do the resize (resample)?
By rebl in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jan 2010, 15:46 -
Export frame resample (PAL HDV)
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 16th Jul 2008, 16:07
