i have been using aimersoft video converter to convert mkv files to xvid files that will play on my dvd player.
the problem is that the resulting xvid file will sometimes be very jerky.
does anyone know the best resolution, frame rate and bit rate settings to use to convert mkv files.
Use same frame rate as the mkv source(identify with mediainfo if not aimersoft shows it), max around 720x576 pixels, don't too high video bitrate(1-2Mbit/s).
Or try another mkv to avi xvid converter like xvid4psp 5(use the avi hardware preset), winff, xmedia recode or the simple freemake video converter.
Joing Two Mkv files of different encoding settings issue work around...
By Fusionb in forum EditingReplies: 14Last Post: 5th Feb 2013, 10:17 -
aimersoft best settings for m4v to avi
By goingape in forum Newbie / General discussionsReplies: 2Last Post: 28th Aug 2011, 16:00 -
aimersoft mkv conversion problem...
By freewheelin in forum Video ConversionReplies: 1Last Post: 6th Sep 2009, 14:22 -
Help converting .mkv files.
By hellfire45 in forum Video ConversionReplies: 21Last Post: 7th Nov 2008, 22:22 -
Best settings to use when converting AVI to DVD for 624x464 files?
By Cobra281 in forum Newbie / General discussionsReplies: 5Last Post: 26th Sep 2008, 17:45
