I'm trying to join the m2ts streams of Lord of the Rings, extended cuts which are 2-disc movies.
The best solution so far is using tsMuxeR, eac3to and a script generator. That solution, I found here but isn't perfect...
http://avchdvideos.blogspot.com/p/joining-my-avchd-videos.html
The DTS-Master gets converted to Dolby. To be sure, I've tried tsMuxeR and TSSplitter to join the files but the audio is out of sync after the merge point.
Is there anything new on this?
The video and audio are of slightly different lengths, that's all.
Use Clown_BD to extract main movie from each disc. First tick the checkbox for removing the last second from the movie. The option is there for that very situation.
Then join the m2ts files with tsMuxer and output to BD. From there you can remux to MKV or whatever if you like.
If you need the chapter timings for inputting in tsMuxer, I can post them again. This subject has come up before, not surprisingly.
Pull! Bang! Darn! -
It felt like something simple. It's amazing how much more extensive the other solution was... Heh.
Anyway, the "Click that box," solution worked much better.
Welcome to the forum.
Here are the corrected chapter timings. Just select custom chapters in tsMuxer (under Blu-Ray tab), clear the pane, and copy/paste.
Fellowship of the Ring Extended:
00:00:00.000
00:07:36.790
00:10:35.552
00:15:39.855
00:19:58.489
00:25:32.614
00:29:57.378
00:32:10.679
00:34:51.797
00:36:18.175
00:45:04.159
00:46:44.300
00:51:21.411
00:55:12.434
00:57:30.072
01:03:31.516
01:07:16.114
01:08:53.587
01:10:35.939
01:15:15.386
01:17:46.619
01:24:11.546
01:26:12.501
01:29:41.585
01:33:14.671
01:35:54.082
01:37:32.971
01:45:41.960
01:46:57.786
01:48:41.181
01:49:58.591
01:53:04.402
01:57:50.688
02:04:16.073
02:10:46.421
02:20:11.152
02:29:52.608
02:33:05.259
02:40:22.279
02:46:02.285
02:47:43.636
02:53:06.167
02:57:58.417
03:04:26.179
03:11:42.115
03:14:24.444
03:20:42.613
03:28:23.115
Two Towers Extended:
00:00:00.000
00:04:08.747
00:06:10.829
00:14:44.966
00:17:06.608
00:19:17.948
00:23:07.094
00:23:58.311
00:27:09.044
00:28:03.181
00:31:38.230
00:35:45.518
00:38:17.878
00:41:47.797
00:50:49.755
00:58:19.413
01:00:40.177
01:02:48.306
01:08:05.998
01:12:41.731
01:24:17.344
01:25:41.636
01:27:34.332
01:30:45.523
01:32:30.587
01:34:31.039
01:35:57.042
01:37:02.315
01:38:43.960
01:41:14.819
01:46:37.974
01:47:20.766
01:49:50.625
01:54:57.180
02:01:35.369
02:04:15.489
02:06:51.936
02:08:29.493
02:12:12.256
02:14:38.235
02:18:27.839
02:23:07.410
02:30:29.102
02:36:02.352
02:37:22.224
02:40:30.495
02:42:15.225
02:43:05.899
02:46:39.988
02:53:02.370
02:54:39.426
02:58:04.547
02:59:49.694
03:05:52.181
03:07:17.266
03:07:52.010
03:10:21.534
03:12:53.519
03:17:32.006
03:19:58.360
03:24:43.645
03:25:36.198
03:26:16.738
03:28:20.529
03:30:50.386
03:32:30.069
03:34:54.213
03:43:50.498
Return of the King Extended:
00:00:00.000
00:06:24.341
00:09:21.394
00:11:21.847
00:18:23.310
00:23:05.009
00:27:03.329
00:29:00.696
00:37:06.432
00:40:02.567
00:42:03.228
00:47:52.202
00:50:18.641
00:52:18.760
00:55:35.331
00:59:36.405
01:00:23.702
01:00:50.605
01:04:30.074
01:07:16.032
01:10:35.314
01:14:54.823
01:17:21.970
01:19:21.798
01:20:01.087
01:21:26.798
01:23:48.940
01:29:08.592
01:33:57.590
01:38:08.048
01:42:49.704
01:45:34.244
01:46:57.453
01:49:24.432
01:51:09.997
01:58:39.695
02:07:38.984
02:08:41.462
02:17:49.134
02:19:39.454
02:20:15.823
02:21:49.459
02:22:56.275
02:28:58.012
02:30:03.327
02:32:28.347
02:36:42.768
02:38:49.852
02:43:45.398
02:45:15.822
02:47:01.761
02:47:54.188
02:48:38.440
02:51:14.137
02:53:16.844
02:54:23.786
02:56:39.797
02:57:31.848
03:04:27.764
03:06:10.116
03:07:39.206
03:12:10.726
03:16:22.437
03:19:38.340
03:23:12.138
03:25:24.937
03:26:28.041
03:28:24.115
03:28:58.441
03:34:36.696
03:36:50.079
03:40:19.079
03:42:42.181
03:47:35.223
03:52:17.130
04:01:35.731
04:12:43.146Pull! Bang! Darn!
tsMuxer and joining m2ts files
By fkasparek in forum Blu-ray RippingReplies: 13Last Post: 12th Jun 2014, 12:07 -
Joining/merging m2ts/mp4 and other formats
By nicoliani in forum EditingReplies: 11Last Post: 9th Feb 2013, 10:17 -
Splitting/Joining AVCHD video files (m2ts)
By glenpinn in forum EditingReplies: 17Last Post: 19th Sep 2012, 11:13 -
Joining m2ts files
By theendisnye in forum Authoring (Blu-ray)Replies: 10Last Post: 21st May 2011, 11:51 -
Help: .m2ts joining and adding transitions
By klynax in forum EditingReplies: 2Last Post: 9th Oct 2009, 14:25
