here is what media nfo is saying:
Format : BDAV
Format/Info : Blu-ray Video
File size : 8.57 GiB
Duration : 58mn 32s
Overall bit rate : 21.0 Mbps
Maximum Overall bit rate : 35.5 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : 27
Duration : 58mn 32s
Bit rate mode : Variable
Bit rate : 19.5 Mbps
Maximum bit rate : 36.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.392
Stream size : 7.97 GiB (93%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : 129
Duration : 58mn 32s
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 268 MiB (3%)
Text
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Language : English
I can't figure out the problem, I have tried both 32 and 64 bit mode but it makes no difference. I am trying to fit a lot of these onto one blu ray.
BDRebuilder - x264.exe has stopped working
By kILLDR3n in forum Blu-ray RippingReplies: 6Last Post: 10th Dec 2011, 08:26 -
tsMuxeR.exe has stopped working
By stblob in forum Authoring (Blu-ray)Replies: 8Last Post: 7th May 2011, 14:24 -
Wavi.exe stopped working
By jcknecht in forum Blu-ray RippingReplies: 11Last Post: 1st Jan 2011, 16:24 -
x264_x64.exe has stopped working. (Ripbot 1.15.1) Help.
By theshadow1234 in forum Blu-ray RippingReplies: 4Last Post: 19th Mar 2010, 15:57 -
By newpath in forum Video ConversionReplies: 6Last Post: 17th Jul 2009, 17:42
